Help blown 370 inch small block #2285183
04/10/17 07:57 AM
04/10/17 07:57 AM
SW WI
cudacustoms1 Offline OP
SW WI
I have recently picked up a new project. It is a mini rod pulling tractor that was setup for brand x small block. I would like to use a mopar in it. 370 cu in 8-71 blowers are the basic engine rules. This is a for fun project so have to keep the budget down. I already have a money pit. I have always been a big block guy so I really don't know what is available. What would you build?
Re: Help blown 370 inch small block [Re: cudacustoms1] #2285186
04/10/17 08:58 AM
04/10/17 08:58 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Are aftermarket blocks and heads allowed?
[image][/image]
Re: Help blown 370 inch small block [Re: cudacustoms1] #2285189
04/10/17 09:13 AM
04/10/17 09:13 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Is the rule cubic inch only, or cubic inch small block? You could build a 370in big block.
Re: Help blown 370 inch small block [Re: cudacustoms1] #2285445
04/10/17 08:09 PM
04/10/17 08:09 PM
SW WI
SW WI
Rules are 370" engine. I thought about big block but the problem is cost of aftermarket block. I had considered 354 hemi w/ an used set of Allen johnson heads. Will any of the small block chrysler blocks take living over 1000hp on boost? Trying to do this on somewhat of a budget.
Re: Help blown 370 inch small block [Re: cudacustoms1] #2285470
04/10/17 08:47 PM
04/10/17 08:47 PM
dogdays Offline
dogdays  Offline
IMHO if you need 1000hp you might as well stay home unless you spring for an aftermarket block.
You'd have much better luck with a GIII Hemi. And even that might be on the ragged edge.
One thing's for sure, it's much easier to make 1000hp through a 400cfm port than it is through a 300cfm port.
Good Luck!
R.
Re: Help blown 370 inch small block [Re: cudacustoms1] #2285476
04/10/17 08:58 PM
04/10/17 08:58 PM
sgcuda Offline
sgcuda  Offline
A 5.7 Gen3 with a 6.4 crank will give you 372 cubes. The right set of heads will yield 1,000 hp boosted and should hold together fairly nicely. I know turbo guys are pulling more hp than that and living on stock blocks.
[image][/image]
Re: Help blown 370 inch small block [Re: cudacustoms1] #2285483
04/10/17 09:09 PM
04/10/17 09:09 PM
P
Porter67 Offline
Porter67  Offline
P
Oh yea, if your hooking to a sled a oem block will not be your friend.
1000hp on boost? Trying to do this on somewhat of a budget....
Thats crazy talk.
Re: Help blown 370 inch small block [Re: cudacustoms1] #2285648
04/11/17 01:32 AM
04/11/17 01:32 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
R3 block, w8 or w9 heads and you wouldn't have a problem making 1000 hp. Hard part find a good r3 block.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Help blown 370 inch small block [Re: cudacustoms1] #2285750
04/11/17 10:40 AM
04/11/17 10:40 AM
rpagan Offline
rpagan  Offline
I have a 365 cu in rotating assembly for a R3 short deck block set-up for twin turbo should you find the need. Should be fine supercharged also. As 1967dartgt already pointed out an R3 with w8-w9 heads 1000hp would be no problem.
Re: Help blown 370 inch small block [Re: sgcuda] #2285988
04/11/17 08:07 PM
04/11/17 08:07 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
This is the cheapest and strongest way to go.
The heads will flow enough for 1000hp without exotic stuff.
Matt
Re: Help blown 370 inch small block [Re: MattW] #2286318
04/12/17 11:28 AM
04/12/17 11:28 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Matt
My be cheaper but no way a factory gen 3 block is stronger then a R3 block.
Re: Help blown 370 inch small block [Re: 1967dartgt] #2286548
04/12/17 06:58 PM
04/12/17 06:58 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Matt
5.7 maybe not but hellcat or 6.4 truck block I would say just as strong and cheaper. No silly machining, block is ready to go for 1600.00.
Oh and the biggest advantage is I can get one right now.
Matt
