Help me identify 8.75 3.91 gear set
#2285097
04/10/17 12:15 AM
04/10/17 12:15 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
I got this 8.75 3.91 gear set that I need to identify. It's a straight pinion that appears to be 1 3/8 diameter but has a collar that measures 1 3/4, can you help?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Help me identify 8.75 3.91 gear set
[Re: DoctorDiff]
#2285136
04/10/17 01:58 AM
04/10/17 01:58 AM
AZ_A12_BEE
Dreaming of the 808
That is a 29 spline 741 gear set. Is the collar part of the set?
37 Plymouth PU
