Trunk tension adjustment tips #2285013
04/09/17 09:31 PM
04/09/17 09:31 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
67 Coronet and I need to increase the tension on my trunk lid as it wont stay up..
I am guessing I need to get in the trunk and shut it ( less tension) and pry the tensioner bars out and over another slot..
Do I need to shut the trunk?? Is a pry bar correct to use or something else?
Any help appreciated..
Re: Trunk tension adjustment tips [Re: minivan] #2285019
04/09/17 09:43 PM
04/09/17 09:43 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
A pry bar would scratch the paint. I normally take an old rubber V-belt and loop it around the tensioner and pull to where I want it set. I do this from outside the trunk. Hold on to the belt and use your body weight for leverage.
