Re: Brake experts needed
[Re: Challenger 1]
#2285041
04/09/17 10:30 PM
04/09/17 10:30 PM
RapidRobert
split the MC and booster & measure the rounded booster pushrod nub clearance to the bottom of the MC rear piston "thimble". want ~.020"
[Re: RapidRobert]
#2285049
04/09/17 10:36 PM
04/09/17 10:36 PM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
split the MC and booster & measure the rounded booster pushrod nub clearance to the bottom of the MC rear piston "thimble". want ~.020" Yes, you have to have some free play between the pushrod and the master cylinder. Otherwise it just continues to build pressure and never releases correctly. Check that first before you do anything else. The pushrod should have an adjustment on the end.
[Re: 70VcodeCoronetRT]
#2285053
04/09/17 10:43 PM
04/09/17 10:43 PM
Posts: 1,705 Nebraska
70VcodeCoronetRT
Nebraska
Checked the pushrod looks good there. I did this test I got from the SSBC site.
This procedure will require the use of a hand operated vacuum pump with a vacuum gauge. If you do not own one it can often be rented or borrowed from most “big box” parts stores. (Note: 18”HG is the minimum engine vacuum at idle in gear to effectively operate a vacuum booster 1) Remove vacuum hose from check valve on booster. Place hose from vacuum pump onto check valve and draw booster to 20” of vacuum. 2) Let booster sit with vacuum applied for 5 minutes. If vacuum does not stay steady at 20” it is faulty and needs to be replaced. If vacuum does hold steady at 20” proceed to step 3. 3) With 20” of vacuum in booster depress brake pedal once and release it. The booster should transfer some but not the entire vacuum in reserve. Depending on how hard the pedal is depressed it is normal to see 5-10” of vacuum depleted from reserve. The most important thing is to ensure the booster does transfer vacuum but does NOT transfer the entire vacuum in its reserve. If vacuum remains at 20” OR goes to zero the booster is bad and will need to be replaced. If vacuum transfer is within the above parameter proceed to step 4. 4) Once again draw booster down to 20” of vacuum. Go inside car and depress brake pedal and hold down for 30 seconds. You should see the gauge drop slightly and then hold steady. Vacuum should stay steady as long as you are holding the pedal down. If vacuum drops while pedal is being held down the booster is faulty and will need to be replaced.
My booster held the 20"of vacuum. But when I pressed the pedal it lost 15" of vacuum. Taking it down to 5". And if I held the pedal it lost all vacuum. So if this is a relevant test. My booster looks to be bad.
#2285058
04/09/17 10:50 PM
04/09/17 10:50 PM
Guitar Jones
