I had same problem except front disc brakes grabbed and wouldn't release at all unless pet cock on caliper was loosened and fluid drained out. The fluid would not go back to the master cylinder because it was full of crud.
Make sure that the master cylinder is really clean and the shuttle valve is working smoothly.
As mentioned in previous post: replace the rubber hoses if old as they also act like one way valves if the inside linings are bad.
