Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 #2284838
04/09/17 03:24 PM
04/09/17 03:24 PM
ghinmi Offline OP
ghinmi  Offline OP
Hit up the track yesterday with surprising results. Combo is a 2010 Challenger 5.7/6 speed. Cable drive throttle body, vvt disabled, 80 lb injectors, Bullseye 66mm turbo with 7 psi on 93 pump gas. Jeep weighs 3990 lbs. The 11.14 was on a really soft launch, by the time I started gaining on it the transmission wasn't playing nice so no 10s yet. This little 5.7 is a workhorse, I'm impressed with it. Made 535 to the tire at 5500 rpm last weekend.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2284953
04/09/17 07:19 PM
04/09/17 07:19 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
thumbs First time to the track with it?
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2284995
04/09/17 08:31 PM
04/09/17 08:31 PM
ghinmi Offline OP
ghinmi  Offline OP
No, I've gone a couple times with this one and also did Drag Week with it last year. Just picked up a bunch of mph since last time. Previous best was an 11.46 @ 120.2
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285143
04/10/17 02:25 AM
04/10/17 02:25 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
What is the story on the engine? Aftermarket stuff? Heads ported??
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285148
04/10/17 02:35 AM
04/10/17 02:35 AM
ghinmi Offline OP
ghinmi  Offline OP
Just the vvt locked out, injectors, throttle body, and truck oil pan to clear the crossmember. The front cover has been off to lock the vvt but aside from that the motor has never been apart. Still on the original spark plugs that I re-gapped to .030 because it was blowing out spark. It's actually on the original clutch as well. Motor and trans have roughly 63k miles on them, 6500 of those with the turbo setup.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285240
04/10/17 12:01 PM
04/10/17 12:01 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That is an awesome combo man, looks like fun.
68 Barracuda Formula S 340
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285260
04/10/17 12:35 PM
04/10/17 12:35 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
What frame/suspension are you using?
Have a great day
Iowan
"obsolete is neat"
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285317
04/10/17 02:42 PM
04/10/17 02:42 PM
State College, Pennsylvania
fatman Offline
fatman  Offline
Thanks for posting, this is a favorite of mine.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285578
04/10/17 11:32 PM
04/10/17 11:32 PM
ghinmi Offline OP
ghinmi  Offline OP
Thanks! I know it won't be the most popular here but it's on a '71 Chevy C10 chassis shortened 17" and reworked suspension. The whole truck is a mutt, whatever works and is cheap.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285797
04/11/17 12:59 PM
04/11/17 12:59 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Very cool build. Run what you've got. Wish my Challenger would run like that.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285870
04/11/17 03:52 PM
04/11/17 03:52 PM
Renton Washington
Triple Threat Offline
Renton Washington
That's a sweet build and it runs hard. Congrats!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2296254
04/29/17 10:22 PM
04/29/17 10:22 PM
ghinmi Offline OP
ghinmi  Offline OP
Drove it to the track again yesterday and put the best stats from those two slips together. Went 1.57 sixty and 10.97 @ 125.2 on the first pass. Slapped on the 315/35r17 hard street tires and managed a 1.99 sixty, 11.50 @ 124.2 on the second attempt. Super happy with this simple motor combo.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2296347
04/30/17 01:33 AM
04/30/17 01:33 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
That is a beast man. Nice, "simple", and working like a champ...
SuperBeast
An enforcer for the Mopar Mafia!
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2303032
05/11/17 09:32 PM
05/11/17 09:32 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I was going to say you have the mph for 10's. I know boosted cars usually mph more then N/A as I am but glad to see you got your 10. It seems N/A usually 60 ft a little better then boosted cars also but you are running real good. Ron
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: 383man] #2303399
05/12/17 03:55 PM
05/12/17 03:55 PM
ghinmi Offline OP
ghinmi  Offline OP
Yep, there's definitely a good bit left in it with a good clutch and some suspension changes. I just don't want to sacrifice handling for et since it's built to do autocross with. The 11.50 was in full autocross trim and the 10.97 was just a tire swap, no suspension changes.
I'm still amazed at the mph, it's 10 mph higher than I ever thought it would be.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2305831
05/17/17 01:09 AM
05/17/17 01:09 AM
SoCal
Frank Cannon Offline
SoCal
That's a cool truck.
CALIFORNIA-SUNDAY-10:04 A.M.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2306365
05/17/17 10:50 PM
05/17/17 10:50 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Great job. I love how simple it is, and just plain works!!
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2306873
05/18/17 05:30 PM
05/18/17 05:30 PM
ghinmi Offline OP
ghinmi  Offline OP
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2325990
06/24/17 01:47 AM
06/24/17 01:47 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Awesome.... smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2580655
11/20/18 03:27 PM
11/20/18 03:27 PM
ghinmi Offline OP
ghinmi  Offline OP
Some updates. The red Jeep got wrecked last summer and I built a new one. Same drivetrain. Did pistons/rods and no other changes other than upping the boost. The little 5.7 and s366 keeps performing. Has been 10.90 @ 130 on the low profile Continental street tires and 10.38 @ 132.6 on a 28x10.5 slick. The 10.38 pass was actually very soft, only went 1.56 sixty foot because the clutch was on it's way out. Has been 1.46 so should go a good bit quicker with all that mph in the Spring.
Also drove it from Michigan to Atlanta, did Drag Week, and drove it home. 2805 miles in a week and 13 passes.
Have also done some autocrossing with it, you can see how linear the power is and how little lag the tiny turbo has.
