Hit up the track yesterday with surprising results. Combo is a 2010 Challenger 5.7/6 speed. Cable drive throttle body, vvt disabled, 80 lb injectors, Bullseye 66mm turbo with 7 psi on 93 pump gas. Jeep weighs 3990 lbs. The 11.14 was on a really soft launch, by the time I started gaining on it the transmission wasn't playing nice so no 10s yet. This little 5.7 is a workhorse, I'm impressed with it. Made 535 to the tire at 5500 rpm last weekend.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
Entire Thread
Subject
Posted By
Posted
Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6
