Odd oil pressure issue
#2186357
10/31/16 12:17 AM
10/31/16 12:17 AM
Posts: 20,177 Park Forest, IL
slantzilla
Park Forest, IL
The 340 I put in my Duster made 75 psi when I primed it with an air drill on the stand. It made 75 psi cold at idle when I started it up 3 weeks ago. Warm it made 45 at idle and 75 revved up some. Today I fired it up and it was making 80 cold at idle and 95 just off idle. Warm it was at 60, and 80 revved up. Should I be concerned? It has 10-30 Pennzoil in it, and it was in the low 60s today. It was in the mid 70s when I fired it last time, so I wouldn't believe temperature to be an issue. Thanks!
Re: Odd oil pressure issue
[Re: Jeremiah]
#2186373
10/31/16 12:36 AM
10/31/16 12:36 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Sounds to me like a lot of oil pressure I would verify with another gauge... would be my first step
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: slantzilla]
#2186391
10/31/16 01:04 AM
10/31/16 01:04 AM
Posts: 7,506 Az
Crizila
Az
That's a lot of pressure for 10-30 warm big D, but I would just keep monitoring it for now. Changing filters is a good idea - and maybe cut the old one open.
Fastest 300
[Re: slantzilla]
#2186426
10/31/16 02:26 AM
10/31/16 02:26 AM
slantzilla
Park Forest, IL
It'' got a NAPA Gold filter on it, I let it run for about 20 minutes and it didn'' balloon it.
I don'' think it'' the gauge, but it is an older Autometer mechanical.
I will fire it up next weekend when I am down there again.
Thanks guys!
[Re: slantzilla]
#2187654
11/01/16 09:12 PM
11/01/16 09:12 PM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
20 or so years ago when I was building sb mopars for one of the oval track teams, I found that in those things, the melling high volume pumps would almost always produce over 100psi of hot oil pressure at rpm. I had a couple that were close to 140.
No real clarity from melling on why this was, but installing std pumps cured it. They were 75-80 hot oil pressure at rpm.
I never had any issues from the high oil pressure. Those motors all ran thousands of laps and I never had any of them fail from an oil related problem.
[Re: slantzilla]
#2188040
11/02/16 02:27 PM
11/02/16 02:27 PM
slantzilla
Park Forest, IL
I am just guessing it may have a chunk of crap stuck in the relief valve or something. I did change the pan and put the original pump back in the motor before I put it in. (When I had the motor in my truck I used the truck pan and pump on it.)
At least picked up oil pressure from when I fired it, if it would have lost 20 I would be really concerned.
[Re: slantzilla]
#2284413
04/08/17 02:28 PM
04/08/17 02:28 PM
slantzilla
Park Forest, IL
Was at the shop and fired the Duster and moved it out to warm up. Had 90 cold at idle when I put it outside. Moved some other stuff around and checked on the Duster. It is now back to 30 hot at idle and 75 revved up a little. Hoping to be able to get the rear under it before too long and get it to the track.
[Re: slantzilla]
#2284482
04/08/17 05:22 PM
04/08/17 05:22 PM
crabman173
crabman173
Melling has had that issue with sb pumps for a LONG time some had BB relief some had hole for it drilled .100 thou shallow thus like shimmimg--it never ends I fired a new one up yesterday--it did not prime up "tight" but wth fired it up no oil pressure after all the trouble tear down etc it was a defective new pump---pumped like a squirt gun--new pump and a 20 hour thrash and it all looks good today--an UNPAID thrash Some days I just want to go get a job selling golf clubs and never mention engines ever again
[Re: ]
#2284689
04/09/17 05:14 AM
04/09/17 05:14 AM
slantzilla
Park Forest, IL
OUCH!
