Odd oil pressure issue #2186357
10/31/16 12:17 AM
10/31/16 12:17 AM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
The 340 I put in my Duster made 75 psi when I primed it with an air drill on the stand. It made 75 psi cold at idle when I started it up 3 weeks ago. Warm it made 45 at idle and 75 revved up some.
Today I fired it up and it was making 80 cold at idle and 95 just off idle. Warm it was at 60, and 80 revved up.
Should I be concerned? It has 10-30 Pennzoil in it, and it was in the low 60s today. It was in the mid 70s when I fired it last time, so I wouldn't believe temperature to be an issue.
Thanks! wave
Re: Odd oil pressure issue [Re: slantzilla] #2186365
10/31/16 12:26 AM
10/31/16 12:26 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
95 is pretty high. Apparently you have a quality oil filter or this would be a DAMHIK post. Is it possible the relief valve is sticky? Try a new oil filter perhaps?
Re: Odd oil pressure issue [Re: Jeremiah] #2186373
10/31/16 12:36 AM
10/31/16 12:36 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Sounds to me like a lot of oil pressure I would verify with another gauge... would be my first step
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Odd oil pressure issue [Re: slantzilla] #2186391
10/31/16 01:04 AM
10/31/16 01:04 AM
Az
Crizila Offline
Crizila  Offline
Az
That's a lot of pressure for 10-30 warm big D, but I would just keep monitoring it for now. Changing filters is a good idea - and maybe cut the old one open.
Fastest 300
Re: Odd oil pressure issue [Re: slantzilla] #2186426
10/31/16 02:26 AM
10/31/16 02:26 AM
Park Forest, IL
Park Forest, IL
It'' got a NAPA Gold filter on it, I let it run for about 20 minutes and it didn'' balloon it.
I don'' think it'' the gauge, but it is an older Autometer mechanical.
I will fire it up next weekend when I am down there again.
Thanks guys!
Re: Odd oil pressure issue [Re: slantzilla] #2187654
11/01/16 09:12 PM
11/01/16 09:12 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
20 or so years ago when I was building sb mopars for one of the oval track teams, I found that in those things, the melling high volume pumps would almost always produce over 100psi of hot oil pressure at rpm. I had a couple that were close to 140.
No real clarity from melling on why this was, but installing std pumps cured it.
They were 75-80 hot oil pressure at rpm.
I never had any issues from the high oil pressure. Those motors all ran thousands of laps and I never had any of them fail from an oil related problem.
Re: Odd oil pressure issue [Re: fast68plymouth] #2187879
11/02/16 04:04 AM
11/02/16 04:04 AM
I had the same thing happen on several Melling SB Mopar high volume pumps, they had the BB bypass valve in them runaway
I pulled the retaining plug and install a SB valve and new welsh plug was all it took to fix it up runaway shruggy
The trials and tribulations of engine building whistling
Re: Odd oil pressure issue [Re: slantzilla] #2188040
11/02/16 02:27 PM
11/02/16 02:27 PM
Park Forest, IL
Park Forest, IL
I am just guessing it may have a chunk of crap stuck in the relief valve or something. I did change the pan and put the original pump back in the motor before I put it in. (When I had the motor in my truck I used the truck pan and pump on it.)
At least picked up oil pressure from when I fired it, if it would have lost 20 I would be really concerned.
Re: Odd oil pressure issue [Re: slantzilla] #2284413
04/08/17 02:28 PM
04/08/17 02:28 PM
Park Forest, IL
Park Forest, IL
Was at the shop and fired the Duster and moved it out to warm up. Had 90 cold at idle when I put it outside.
Moved some other stuff around and checked on the Duster. It is now back to 30 hot at idle and 75 revved up a little.
Hoping to be able to get the rear under it before too long and get it to the track. boogie
Re: Odd oil pressure issue [Re: slantzilla] #2284482
04/08/17 05:22 PM
04/08/17 05:22 PM
crabman173
crabman173
Melling has had that issue with sb pumps for a LONG time
some had BB relief some had hole for it drilled .100 thou shallow thus like shimmimg--it never ends
I fired a new one up yesterday--it did not prime up "tight" but wth fired it up no oil pressure after all the trouble tear down etc it was a defective new pump---pumped like a squirt gun--new pump and a 20 hour thrash and it all looks good today--an UNPAID thrash
Some days I just want to go get a job selling golf clubs and never mention engines ever again
Re: Odd oil pressure issue [Re: ] #2284689
04/09/17 05:14 AM
04/09/17 05:14 AM
Park Forest, IL
Park Forest, IL
OUCH! fan
