Bigger Tire for Stock 17 in. Rims? #2284286
04/08/17 04:29 AM
04/08/17 04:29 AM
Southern Missouri
Wailin D Offline OP
Wailin D  Offline OP
Southern Missouri
I have 2004 Dodge Ram 2500 2WD diesel. It still has the stock 265-70-17 tires. They look small for the truck and, since I need to get some new tires, I wondered if a larger sized tire could be used without causing issues. I don't really care too much about the width as much as the height. Just would like tires that are more in proportion with the truck using the stock rims. The old 2WD late 70s and 80s 3/4 ton trucks had tires with some tall sidewalls that really filled the wheel well. Any recommendations would be greatly appreciated.
Thanks,
Wailin
Re: Bigger Tire for Stock 17 in. Rims? [Re: Wailin D] #2284685
04/09/17 04:34 AM
04/09/17 04:34 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
I know that a lot of guys run 285/70R17 on their 4WD trucks with 17 inch wheels.
I'm not sure though on a 2wd truck though.
Re: Bigger Tire for Stock 17 in. Rims? [Re: Wailin D] #2288042
04/15/17 02:29 AM
04/15/17 02:29 AM
Southern Missouri
Wailin D Offline OP
Wailin D  Offline OP
Southern Missouri
Thank you for the response SNK-EYZ.
