Tools needed for 904 rebuild? #2283850
04/07/17 11:23 AM
04/07/17 11:23 AM
P
Porter67 Offline OP
Porter67  Offline OP
P
What specialty tools are needed if any?
Thanks.
Re: Tools needed for 904 rebuild? [Re: Porter67] #2284264
04/08/17 01:56 AM
04/08/17 01:56 AM
GEORGIA
barracuda7199 Offline
GEORGIA
Bushing installer and something to compress the clutch pack return spring. C clamps can be used.
Re: Tools needed for 904 rebuild? [Re: Porter67] #2284746
04/09/17 12:37 PM
04/09/17 12:37 PM
OT I would clean the outside case surgically clean then with it on it side/belly up, with your dial indicator measure the input shaft end play clearance & write that on the inside bell face with a magic marker for future reference then slide hammer the pump out & pull the pan & get after it. need expanding snap ring pliers with the thin flat ends for the ext housing big snap ring. taking notes (pics even better) is a good plan.
Re: Tools needed for 904 rebuild? [Re: RapidRobert] #2288093
04/15/17 09:40 AM
04/15/17 09:40 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
Service manual. I take my clutch packs to a local transmission shop and they have done this for free in 3 different towns. Just be nice.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Tools needed for 904 rebuild? [Re: Porter67] #2288139
04/15/17 11:51 AM
04/15/17 11:51 AM
P
Porter67 Offline OP
Porter67  Offline OP
P
Thanks for the replies, im near re assembly as I had to find some hard parts that were a bit damaged, clutch pack welded itself together and I cut the sungear/drum off and popped the ring on the clutch pack and got it apart.
I made a tool to compress the clutch pack spring and borrowed a friends high dollar set of nearly 100 different solid dolls? to r N r the bushings.
Im gonna get a few more performance parts to dump in it and proceed.
In the past ive just tossed the clutches in and a few seals and gaskets and ran with it.
This time its everything and a semi fun time.
I did find a few good vids on you tube that really helped that I watched them before hand.
