98 ram 1500 brake issue, help! #2282789
04/05/17 01:10 PM
04/05/17 01:10 PM
central illinois
65dodgebob Offline OP
central illinois
Hey everyone, my 98 ram 4x4 keeps having a brake caliper sticking issue. I have replaced caliper couple of times,new pads, bled brakes til I'm blue in the face.it will drive fine for awhile, then the driver side caliper will start applying brake while you are going down the road. When I stop you can smell brake pad,and wheel is hot. Thanks for any suggestions.
Re: 98 ram 1500 brake issue, help! [Re: 65dodgebob] #2282802
04/05/17 01:24 PM
04/05/17 01:24 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Replace the brake hose to the LF. It's likely collapsed.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 98 ram 1500 brake issue, help! [Re: 71yelladustr] #2282831
04/05/17 02:14 PM
04/05/17 02:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed, common problem on the Ram rust buckets, if it ain't gas tank straps rusting out it's brake lines, including rubber ones, they usually get built up with rust inside allowing the caliper to retain pressure, I'd replace ALL the rubber lines upfront, been there, done that
Re: 98 ram 1500 brake issue, help! [Re: 65dodgebob] #2282844
04/05/17 02:30 PM
04/05/17 02:30 PM
central illinois
central illinois
Thanks, I will try that.
Re: 98 ram 1500 brake issue, help! [Re: 65dodgebob] #2283043
04/05/17 09:34 PM
04/05/17 09:34 PM
IN
ahy Offline
ahy  Offline
IN
I had the same problem on a '98 Neon. New hoses fixed it (thanks MOPARTs). Agree with the hose recommendation.
Re: 98 ram 1500 brake issue, help! [Re: ahy] #2283088
04/05/17 10:58 PM
04/05/17 10:58 PM
next time it does it, pull over & crack the bleeder (open it then shut it) & see if that releases it. EDIT do it if possible on a deserted stretch of road & go aways WO hitting the brake & see if it cools off/or stays free.
Re: 98 ram 1500 brake issue, help! [Re: RapidRobert] #2283222
04/06/17 06:24 AM
04/06/17 06:24 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
has the same issue with our 99 ram van...
Brake line replaced, good after that,.
Re: 98 ram 1500 brake issue, help! [Re: RapidRobert] #2283838
04/07/17 11:02 AM
04/07/17 11:02 AM
moparx Online content
moparx  Online Content
another option on this same approach is to crack the banjo bolt. this is "if" your bleeder screw is really rusty, and the banjo bolt is easier to get to with the front wheel cranked the whole way to which ever direction offers the best access to the bolt.
beer
Re: 98 ram 1500 brake issue, help! [Re: 65dodgebob] #2284072
04/07/17 06:01 PM
04/07/17 06:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I usually replace the rubber hoses when I replace the caliper just for that reason.
