Re: 98 ram 1500 brake issue, help!
[Re: 65dodgebob]
#2282802
04/05/17 01:24 PM
04/05/17 01:24 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Replace the brake hose to the LF. It's likely collapsed.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#2282831
04/05/17 02:14 PM
04/05/17 02:14 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Replace the brake hose to the LF. It's likely collapsed. Agreed, common problem on the Ram rust buckets, if it ain't gas tank straps rusting out it's brake lines, including rubber ones, they usually get built up with rust inside allowing the caliper to retain pressure, I'd replace ALL the rubber lines upfront, been there, done that
[Re: ahy]
#2283088
04/05/17 10:58 PM
04/05/17 10:58 PM
RapidRobert
next time it does it, pull over & crack the bleeder (open it then shut it) & see if that releases it. EDIT do it if possible on a deserted stretch of road & go aways WO hitting the brake & see if it cools off/or stays free.
