Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2284201
04/07/17 10:54 PM
04/07/17 10:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
BES built a 401 NA that made 700 under 6500 RPM for the engine masters a few years back, add another 20-30 cubes, a few more RPM and don't follow all the engine master rules and a normal guy should be able to do it.
I like NA because it is more simple under the hood than any other power adder. I get sick of working on these new fangled cars for a living because they try to stuff so much stuff under the hood, I want my hotrod to be simple.
Re: Stroker or Forced induction? [Re: HotRodDave] #2285930
04/11/17 06:08 PM
04/11/17 06:08 PM
dogdays Offline
dogdays  Offline
If you want to read a well-written discussion of 300M, go to the website:
http://www.epi-eng.com/
Then click on the Piston Engine Technology button, then on the connecting rod subject.
Whether your connecting rods have notch sensitivity or not depends on the heat treat. This is discussed in that chapter.
R.
Re: Stroker or Forced induction? [Re: WO23Coronet] #2287268
04/13/17 09:12 PM
04/13/17 09:12 PM
Superfreak
Superfreak
Originally Posted By WO23Coronet
A 2.9 Whipple will make a 1000 hp, it's fairly affordable, and it's a bolt on, give you plenty of leg to outrun a Hellcat. Turbos make a pile of HP but so does a twin screw. A supercharger would look more at home in a muscle car and give you that snorty, instant throttle response
If you call $7000 plus affordable.
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2287303
04/13/17 10:22 PM
04/13/17 10:22 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
For the kind of power it can put out it's very affordable, and a smart way to do it. Drives like a pussycat but 1000 hp when you nail it, I'd say 7K well spent. Probably more like 10K, the drop in piston/rod combo is around 2K, the other 1K for head studs, good gaskets, headers etc. Unless you start with a big gas truck engine, they already come with forged pistons apparently
