Re: Hemi Build
[Re: rickseeman]
#2282112
04/04/17 11:42 AM
04/04/17 11:42 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
as the old saying goes: speed costs money son How fast do you want to go!
Hell Hath No Fury Like Mine
Re: Hemi Build
[Re: Cuda340]
#2282154
04/04/17 12:45 PM
04/04/17 12:45 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Haha, understood! How about 700+HP on pump gas and yes fit under a stock hood. This isn't going to be a "hypothetical" build this will be real. So lets spend some money!
Re: Hemi Build
[Re: Cuda340]
#2282173
04/04/17 01:07 PM
04/04/17 01:07 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Are you sure that is not a siamese bore block ? It has notches for rod clearance in stroked applications? Was there a yellow tag on the rear that said not to bore past a certian overbore size ?
700HP ... stroke it.... put a 4.25 arm in it with 2.2 rod journals for starters.
Dual quads or single carb ?
Re: Hemi Build
[Re: Cuda340]
#2282181
04/04/17 01:17 PM
04/04/17 01:17 PM
Cuda340
Wheatfield, NY
Yeah John, it is a water block small bore, not the Siamese version. This was made in about 2001 I believe. I was thinking at least a 4.25 crank, but was wondering if a 4.375" crank to get me over 500" is doable with the stock oiling system (or even worth it), I don't believe a 4.500" crank will fit with a stock pick up. There was no yellow tag, but if you look at the top picture I posted above it shows how (specs) the block came from MP. Overbore capacity is 4.31". This will be a dual quad motor.
Re: Hemi Build
[Re: Cuda340]
#2282189
04/04/17 01:28 PM
04/04/17 01:28 PM
Posts: 4,179 California
mickm
California
You are defiantly going to need to bore and stroke to get 700 out of it. Well, I should say if you want a steerable 700... And then again, we all have a different opinion of steerable....
My build is a siamese block, 4.5X4.25, 540ci. Around 10.25:1, Stage V heads prepped by FHO, and the cam is roughly 248 @ .050 .605 I .580 E. Numbers probably aren't exact, but close enough. MSD with a Chrysler electronic distributor, Stage V intake with 2 Edelbrock 650's.
Dyno'd at 712 HP @ 6000. That was at 34 degrees timing. It was pulling 6-7 more hp per hundred RPM at 32 degrees, but that was the end of a long, long day, and it was good enough for me!
I chose a somewhat mild cam, for 540 inches, as I wanted power, but streetabliity. There are times when this car gets driven a lot.
Re: Hemi Build
[Re: mickm]
#2282199
04/04/17 01:38 PM
04/04/17 01:38 PM
Cuda340
Wheatfield, NY
I chose a somewhat mild cam, for 540 inches, as I wanted power, but streetabliity. There are times when this car gets driven a lot. Did Tim at FHO build your Hemi? Roller Cam? What Rockers?
Re: Hemi Build
[Re: Cuda340]
#2282215
04/04/17 02:05 PM
04/04/17 02:05 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
a 4.25 crank with a 2.2 rod journals is about perfect for your application. It will fit with the internal oil pickup. A 4.375 might fit, depending on the block, so had the hole a little farther out. 700-800 horse should be easy with the right cam and heads, and decent compression.
Mickm, I'm sure there is a reason you went with a small cam like that, but I think you are leaving 100 horsepower on the table.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Hemi Build
[Re: cudadoug]
#2282290
04/04/17 04:03 PM
04/04/17 04:03 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
I would run the 4.375 crank. Stage V heads are great or the new Edelbrocks look pretty good as well, might be cheaper to run the Edelbrocks I think. Plan on a 650ish solid Roller cam, you don't want to chance losing a flat lifter and damaging anything with the shrapnel. Stage V dual 4 intake works great. I would also plan on injecting it from the get go, it isn't 1971 anymore.
Sheldon
Sheldon
Re: Hemi Build
[Re: Cuda340]
#2282292
04/04/17 04:09 PM
04/04/17 04:09 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
Two things to keep in mind when buying and building your motor, how much power will your car handle and how much power can you handle? ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) On that block, does the oil pump pick up screw into the block or is the block machine for the bolt on adapter like the Worlds blocks are? If bolt on try the 4.375 stroke with BB Chevy 2.200 rod journal sizes, if not use the 4.25 stroke with the BB Chevy H beam steel rods ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) As far as the heads, intake, carb. sizes and camshaft buy bigger than needed for stock C.I. size motor ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I'm building a 572 C.I. pump gas hemiroid motor now for a local customer, it will be EFI with dual 4150 bolt pattern 1000 CFM dry throttle bodies with FHO prepare Stage V aluminum heads, FHO Stage V rocker arm assembly, EFI intake for the dual throttle bodies, solid roller cam and so on. I'm hoping and expecting 750 + HP and similar torque ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif) I cam and do make more HP with wedge motors similarly equip than I can with 426 style Hemiroid motors ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
Re: Hemi Build
[Re: Cab_Burge]
#2282299
04/04/17 04:19 PM
04/04/17 04:19 PM
Cuda340
Wheatfield, NY
Two things to keep in mind when buying and building your motor, how much power will your car handle and how much power can you handle? ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) On that block, does the oil pump pick up screw into the block or is the block machine for the bolt on adapter like the Worlds blocks are? If bolt on try the 4.375 stroke with BB Chevy 2.200 rod journal sizes, if not use the 4.25 stroke with the BB Chevy H beam steel rods ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) As far as the heads, intake, carb. sizes and camshaft buy bigger than needed for stock C.I. size motor ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I'm building a 572 C.I. pump gas hemiroid motor now for a local customer, it will be EFI with dual 4150 bolt pattern 1000 CFM dry throttle bodies with FHO prepare Stage V aluminum heads, FHO Stage V rocker arm assembly, EFI intake for the dual throttle bodies, solid roller cam and so on. I'm hoping and expecting 750 + HP and similar torque ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif) I cam and do make more HP with wedge motors similarly equip than I can with 426 style Hemiroid motors "On that block, does the oil pump pick up screw into the block or is the block machine for the bolt on adapter like the Worlds blocks are?" I will have to check.
Re: Hemi Build
[Re: Cuda340]
#2282339
04/04/17 05:25 PM
04/04/17 05:25 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
call Tim at FHO he'll tell you Exactly what you'll need even if he doesn't build it. (let him build it!)
Re: Hemi Build
[Re: sixpacksteve]
#2282383
04/04/17 06:28 PM
04/04/17 06:28 PM
Cuda340
Wheatfield, NY
call Tim at FHO he'll tell you Exactly what you'll need even if he doesn't build it. (let him build it!) That call has been made, and he will get the nod.....
Re: Hemi Build
[Re: Cuda340]
#2282631
04/05/17 01:43 AM
04/05/17 01:43 AM
mickm
California
I chose a somewhat mild cam, for 540 inches, as I wanted power, but streetabliity. There are times when this car gets driven a lot. Did Tim at FHO build your Hemi? Roller Cam? What Rockers? I had long conversations with Tim about exactly what I wanted, then he packaged everything he had up and sent it out, and then I assembled the engine. Tight lash roller cam, I forget what rockers. I wanted stock valve covers, and I think Tim chose something else for me as StageV won't fit under stock covers.
Re: Hemi Build
[Re: Hemi_Joel]
#2282632
04/05/17 01:47 AM
04/05/17 01:47 AM
mickm
California
Yes, I defiantly am. As I mentioned in the last post, long conversations with Tim. In the end we went with that cam because: 1) I didn't want to be messing with new lifters all the time. So I have good lifters and a relatively mild cam with mild ramps. 2) I wanted it to be drivable, my version of drivable. Car gets driven a lot at times, about to take it down to LA, ~400 miles. With the 2X4's I would get ~14mpg on the highway. Not bad. Will be interesting to see what it does with the six pack. 3) I can only fit 275/60 tires under there. As it is these are useless in 1st and 2nd. I didn't plan on anymore frame modifications, so knew I wouldn't even be able to hook this power well, so with the above 2 factors, this was good enough for me! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: Hemi Build
[Re: mickm]
#2282644
04/05/17 02:25 AM
04/05/17 02:25 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
Yes, I defiantly am. As I mentioned in the last post, long conversations with Tim. In the end we went with that cam because: 1) I didn't want to be messing with new lifters all the time. So I have good lifters and a relatively mild cam with mild ramps. 2) I wanted it to be drivable, my version of drivable. Car gets driven a lot at times, about to take it down to LA, ~400 miles. With the 2X4's I would get ~14mpg on the highway. Not bad. Will be interesting to see what it does with the six pack. 3) I can only fit 275/60 tires under there. As it is these are useless in 1st and 2nd. I didn't plan on anymore frame modifications, so knew I wouldn't even be able to hook this power well, so with the above 2 factors, this was good enough for me! That, my friends is a FFFFFFUN street car!
