Dana 61 in passenger car? #2281762
04/03/17 06:34 PM
04/03/17 06:34 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Currently I have an 8 3/4 in my Charger but the change to a 4-speed and a 500" stroker might warrant an upgrade of the rear axle. I like the 3.23 highway gears I have now but the tallest gears in a Dana 60 are 3.33 (came in some Fords apparently) but they are hard to come by (3.54 being the tallest readily available gears).
Dana 61 axles often have a ratio of 3.07 or 3.31 which theoretically should work well (I'm aware that changing to lower gears is not possible).
Has anyone put a Dana 61 in a passenger car?
Should be pretty straight forward?
Re: Dana 61 in passenger car? [Re: DGS] #2281856
04/03/17 09:50 PM
04/03/17 09:50 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I may be wrong, but isn't a Dana 61 used in the front of a 1 ton 4x4 with a Dana 70 in the back? If that is true doesn't that give some compatibility issues when used as a rear axle?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Dana 61 in passenger car? [Re: Polarapete] #2281889
04/03/17 10:45 PM
04/03/17 10:45 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
They used them in 1st Gen Diesel Dodge pickups before the 518OD trans was available.
My buddy has a 91 W350 single wheel with a 727 and 3.07 gears.
Kevin
Re: Dana 61 in passenger car? [Re: DGS] #2281904
04/03/17 11:06 PM
04/03/17 11:06 PM
Chicago Blackhawks
hemicar1971 Online content
hemicar1971  Online Content
Chicago Blackhawks
Why not just use a gear vender over drive in the car. How many wheel studs in the Dana 61 axles if more than five you are buying axles or if the bolt pattern is different than what rims you have now. There is also another Dana put in Chryslers in C Bodies that could have lower gear ratios. They are rare but one member has one that might be for sale soon. Also what is wrong with the 8 34 if it is a street car and you can spin the tires. You can put axles in the 8 34 and other goodies to make it a lot stronger than stock. I guess you could be wanting that look of a four speed with a dana.
Re: Dana 61 in passenger car? [Re: DGS] #2281932
04/03/17 11:56 PM
04/03/17 11:56 PM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Much easier to use a 9".......
Ed
Re: Dana 61 in passenger car? [Re: Polarapete] #2282009
04/04/17 02:36 AM
04/04/17 02:36 AM
As far as I know the Dana 61 where made as rear ends only on 3/4 and maybe some 1 ton pickups with 3.0 and 3.30 ratio scope
The Dana 60-2 cases where front wheel drives only that used the reverse rotation gear sets for front ends twocents I have been wrong on many things in the past, mainly on stock Mopar production parts confused shruggy
Re: Dana 61 in passenger car? [Re: DGS] #2282220
04/04/17 02:12 PM
04/04/17 02:12 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
If you are just running street tires I would think the 8_3/4 would survive just fine. If you are running slicks or drag radials it may create issues.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Dana 61 in passenger car? [Re: blown340] #2282282
04/04/17 03:48 PM
04/04/17 03:48 PM
dogdays Offline
dogdays  Offline
I believe you can find Dana 61s under some vans and they do not have full floating axles.
The Dana under some C-bodies isn't as strong as a 60/61. It is probably right there with the 8 3/4.
I've been looking at this for a while now, thinking of larger torquier engines.
Your cheapest alternative would probably be a 9 1/4.
R.
Copy from USA Standard Gear:
HOME | DISTRIBUTORS | PRODUCTS | DOWNLOADS | WARRANTIES
Dana 61 Rear - 35 Spline - Dana 61 Rear Semi-Float
Image may vary from actual product
•Ring Gear Diameter: 9.750
•Cover Bolts: 10
•Ring Gear Bolts: 12
•Spline Count: 35
•Dropout: False
•Pinion Support: False
•Carrier Breaks: none
•Rear Suspension: Solid
•Pinion Nut Size: 1-5/16
Compatible with Models:
E-250 3/4 Ton: 1981 - 1983 (Rear)
F-250 3/4 Ton: 1980 - 1982 (Rear)
F-350 1 Ton: 1981 - 1983 (Rear)
Re: Dana 61 in passenger car? [Re: Mr. Smurf] #2282392
04/04/17 06:51 PM
04/04/17 06:51 PM
Chicago Blackhawks
Chicago Blackhawks
Ed
Would agree with a Nine Inch. Lots of rear ends out there and lots of after market parts to put in then. Center sections are easy to change for different gear ratios. Resale value will always be good for a built nine inch.
I still like an over drive in the car. Take a look at the Gear Vender Web Site.
http://www.gearvendors.com/index.html
Re: Dana 61 in passenger car? [Re: Mr. Smurf] #2282554
04/04/17 11:18 PM
04/04/17 11:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Ed
iagree If you want highway gears this is your best choice twocents
Gus beer
64 Plymouth Savoy
Dana 60
