Rod clearance again, (got my dial bore gage) #228116
02/17/09 09:01 PM
02/17/09 09:01 PM
Finally a HUSKER again
Moparnut426 Offline OP
So I got my dial bore gage and I miked my crank, zeroed my dial bore gage, and measured my rod with bearing in and I have .002 on the button. My question is do I have to measure each rod with each bearing because I am leaving a very tiny mark on the bearing from the dial bore gage. I cant feel it with a cotton glove on. It this bearing shot, or can I use it still? Am I being too anal about the marks?
Kasey
Re: Rod clearance again, (got my dial bore gage) [Re: Moparnut426] #228117
02/17/09 09:08 PM
02/17/09 09:08 PM
the proper way is to measure each journal and each bearing.
don't worry about the little scratch, it'll have no effect.
looks like it's coming along great.
Re: Rod clearance again, (got my dial bore gage) #228118
02/17/09 09:16 PM
02/17/09 09:16 PM
As far as my mains, What should they be, and Im having it line hones so I should wait till its done correct? Or can I use a "book" spec, and measure the cran main the same way?
Thanks Dan the Man!!
Kasey
Re: Rod clearance again, (got my dial bore gage) [Re: Moparnut426] #228119
02/17/09 09:29 PM
02/17/09 09:29 PM
Alvadore OR
Acme Rocket Offline
Acme Rocket  Offline
Alvadore OR
I usually check 1 rod and 1 main. But i also check all the housing bores main and rods and mike all journals. I also mike each bearing with a bearing mike. You should check the housing bores on the mains after you get it back from your shop. Sometimes it can be very tricky keeping all the housing bores the same size. I have never worried about the small scratch. Hope this helps
Re: Rod clearance again, (got my dial bore gage) [Re: Moparnut426] #228120
02/17/09 10:55 PM
02/17/09 10:55 PM
You should be able to tell your machine shop that is doing the align hone what size you want it to end up being, on the big side of the factory specs or the small size. Ask them about that as it does have an effect on how much main bearing clearnances you end up with. I would take the crank to the machine shop and have THEM measure it with THIER micrometers and then decide on what size the main bores should end up at so you get the clearnances you want, take the main bearing with you also if you have them, if you don't have them now get them before having the work done. I measure every rod and main bearing torqued up and write them down as soon as I'm done measuring each one, I also maesure every rod and main bearing surface on the crankshaft and write them down so I can do the math to see what the actual clearnances are I'm a firm beleiver in having the clearances on the loose side instead of the tight side, .002 to .003 on the rod bearings using steel rods and .025 to .035 on the mains with stock type main caps
Re: Rod clearance again, (got my dial bore gage) [Re: Cab_Burge] #228121
02/17/09 10:59 PM
02/17/09 10:59 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Re: Rod clearance again, (got my dial bore gage) [Re: jamesc] #228122
02/17/09 11:05 PM
02/17/09 11:05 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Its what them truck bearings call for. mike
Re: Rod clearance again, (got my dial bore gage) [Re: Cab_Burge] #228123
02/17/09 11:44 PM
02/17/09 11:44 PM
Oh Im definatly going to have the shop check it out, but Im one of those guys that wants to check everything my self, I know im not a pro builder, but piece of mind goes a long ways when my foot is going through the floor on this puppy.
I measured them all individually and #3 is a bit tight at .0016, #6 and #7 are both at .0018, All the rest measure from .002 to .0021. Im going to have Kecks machine in Iowa do the work, Im just curious.
It doesnt help that I used to be a machinist, and took many night engine machine classes in college.
Kasey
Re: Rod clearance again, (got my dial bore gage) [Re: Sport440] #228124
02/18/09 12:03 AM
02/18/09 12:03 AM
I don't really know or care what they call for All I know is what I end up with I wish that I could get a little less sometimes but having to much clearnance is way better than having to little, like a lot of things in life
Re: Rod clearance again, (got my dial bore gage) [Re: Cab_Burge] #228125
02/18/09 01:12 AM
02/18/09 01:12 AM
jamesc Offline
jamesc  Offline
comon Cab where's your sense of humor i knew what you meant
Re: Rod clearance again, (got my dial bore gage) [Re: jamesc] #228126
02/18/09 01:48 AM
02/18/09 01:48 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I knew what you meant too It was just a decible infraction on the mains that we were funning you about.
Dont mind me though Cab, You just keep up your good work. You relentlessly help tons of people around here.
Re: Rod clearance again, (got my dial bore gage) [Re: Sport440] #228127
02/18/09 02:58 AM
02/18/09 02:58 AM
Oops, I didn't catch the decimal error on the mains, nobody wants twenty five thousands bearing clearnances, even the top fuel or Harley guys
Re: Rod clearance again, (got my dial bore gage) [Re: Moparnut426] #228128
02/18/09 10:16 AM
02/18/09 10:16 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
That is the only way to go, check it all yourself. Check the main and crank journals for taper and out of round too. My crank had .003" run out when measured at the #3 main bearing and some clearances were too tight. Ended up turning the brand new crank 10/10 to get it right.
Re: Rod clearance again, (got my dial bore gage) #228129
02/18/09 01:09 PM
02/18/09 01:09 PM
organ
maximum entropy Offline
organ
Re: Rod clearance again, (got my dial bore gage) [Re: Sport440] #228130
02/18/09 04:48 PM
02/18/09 04:48 PM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
Decible infraction??? Was Cab being too loud???
