700 CFM heads ??? #2281115
04/02/17 08:47 PM
04/02/17 08:47 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I was talking to one of my Chevy friends today. He said he knows a guy that bought a set of big block Chevy heads that flowed over 500 CFM out of the box. He had a guy port them and now they flow over 700 cfm. I dont know how big the motor is but he said it made over 1100 hp with one carb. I have never heard of any heads that flow that much. Did somebody BS him or is that possible.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 700 CFM heads ??? [Re: D-50] #2281135
04/02/17 09:23 PM
04/02/17 09:23 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Well I can tell you that 1100 HP does not require anywhere near 700 cfm. I cannot know what head he has but 700 cfm would require a MASSIVE intake port and valve. There are some of the Big chevy stuff that are huge but generally only things like the Pro Mod and Mountain motor Pro Stock type stuff. Even the big hemi stuff would be hard pressed to get near that number.
Todd
Re: 700 CFM heads ??? [Re: D-50] #2281143
04/02/17 09:32 PM
04/02/17 09:32 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
I think some of Sonny Leonard's stuff flows in the 700 area...... But those go on motors that are about 1000 cubes.
Re: 700 CFM heads ??? [Re: D-50] #2281175
04/02/17 10:10 PM
04/02/17 10:10 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I saw a pair of Big Chiefs on the flow bench after porting. IIRC, they flowed about 535 and made about 1200 on a 632.
Re: 700 CFM heads ??? [Re: slantzilla] #2281195
04/02/17 10:29 PM
04/02/17 10:29 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
That is what I was thinking. I know the guy he was saying has the heads and I don't think he can afford anything like that. His last car ran in the mid to low 5's in the 1/8. It was one of those old pro cars, I think it is a Oldsmobile Calais or something like that.
Re: 700 CFM heads ??? [Re: D-50] #2281307
04/03/17 01:10 AM
04/03/17 01:10 AM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
I always cry when I see the big Ford stuff flow numbers, I mean c styles are alike 550 out the box😢
Re: 700 CFM heads ??? [Re: n_bogie1984] #2281331
04/03/17 02:16 AM
04/03/17 02:16 AM
So. Burlington, Vt.
So. Burlington, Vt.
Mmmmmmmm..........not exactly.
Re: 700 CFM heads ??? [Re: D-50] #2281336
04/03/17 02:30 AM
04/03/17 02:30 AM
So. Burlington, Vt.
So. Burlington, Vt.
The 700cfm heads from Sonny's start at about $15,000.
Re: 700 CFM heads ??? [Re: D-50] #2281427
04/03/17 11:33 AM
04/03/17 11:33 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
My 5.0 bs Sonny's hemi heads flowed over 600. The ports were small compared to Sonny's 5.3 bs hemi heads. The cost of the heads is cheap compared to the motor they go on. My 762 made over 1500 hp with one 4 bbl. To answer your question, yes there are heads that flow that much, but normally they would be on a larger engine and make a lot more than 1100 hp.
2011 Drag Pak Challenger
Re: 700 CFM heads ??? [Re: fast68plymouth] #2281506
04/03/17 01:09 PM
04/03/17 01:09 PM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
I was making a general statement Dwayne, u know the head game far better then I ever will and that's why u the man! I had just seen a fellow puller post his pro filer c heads and they where 520+ out the box
Re: 700 CFM heads ??? [Re: D-50] #2281508
04/03/17 01:20 PM
04/03/17 01:20 PM
So. Burlington, Vt.
So. Burlington, Vt.
I was referring to Ford Motorsport C heads...... Nowhere near 500 ootb.
I tested a set of hand ported FM C heads...... That the owner was expecting to be around 500cfm. Lets just say he wasn't that happy after he got the flow numbers.
I'm certainly not any kind of authority on Ford stuff...... I didn't realize Profiler had Ford heads.
However, best flowing head I've ever had on my bench was a CNC ported "Thor" head for a BBF, it was like 535cfm.
Second best was an Indy Legend head CNC ported by Jeff at MCH...... It was 499.
I don't see much of that "big stuff".
Re: 700 CFM heads ??? [Re: D-50] #2282156
04/04/17 12:47 PM
04/04/17 12:47 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
We've got a set of SR20's here that goes over 500 at .900 on an SF-1020 with a 4.625 fixture. That's about as much as I've seen a conventional BBC head go. There's reasonable demand for conventional stuff for some of the x275 radial racers where they get a significant weight break. It's all about the rules, if you could get a Predator head under the same ruleset, it'd be very strong. I suspect that's where this 600-13x head will play best.
I'm far from a professional on this stuff, but I'm always surprised how significant an effect various valve/seat angles have on flow performance. It really makes one of the Newen/Serdi single point CNC valve machines look good for a "serious" top end engine program. S/F.....Ken M
Re: 700 CFM heads ??? [Re: EchoSixMike] #2282182
04/04/17 01:19 PM
04/04/17 01:19 PM
The Great White North
RAMM Offline
RAMM  Offline
This is completely hearsay but I remember one of the top cylinder head guys in the USA say a Pro-Stock or Top Fuel V-twin head goes over 700 cfm. FW that's W. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 700 CFM heads ??? [Re: RAMM] #2282576
04/04/17 11:48 PM
04/04/17 11:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Awww man... now I'm developing flowbench envy. wink
