Ignition box with start delay recomendation #2280402
04/01/17 03:44 PM
04/01/17 03:44 PM
ILL
Greentween Offline OP
ILL
Can someone recommend an ignition box that has start delay. I don't know what is out there, and didnt want to spend 500 buck really. I have an FBO box and that is fine (except for starting hot). Need to find a way to get start delay and wanted it to be automatic so I can have wife and or daughter drive it without having hard to start issue.
Re: Ignition box with start delay recomendation [Re: Greentween] #2280471
04/01/17 06:24 PM
04/01/17 06:24 PM
I ain't sure if this is what you are looking for or if this would work for what you want but we had a hot start prob on the stock car & wiring in a momentary NC contact switch to the ign took care of it. (1) press the button (2) get it cranking (3) release the button while cranking. prob solved.
Re: Ignition box with start delay recomendation [Re: Greentween] #2280480
04/01/17 06:41 PM
04/01/17 06:41 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Are you asking about a start retard? Is it slow cranking when the temp. is in the normal range?
Re: Ignition box with start delay recomendation [Re: Dave Hall] #2280548
04/01/17 09:30 PM
04/01/17 09:30 PM
ILL
ILL
Yes. "Start Retard" to back off the timing at startup. I have a kill button off the tach to get it spinning. I would prefer an automatic solution so I dont need to explain how to get it going..
Looks like would need to get higher end ignition box to gain this feature. Seems like there has been some newer Mopar type boxes recently with rpm limiters, but bigger hole in the market is with start retard in a box for around $200.
Re: Ignition box with start delay recomendation [Re: Greentween] #2280706
04/02/17 02:36 AM
04/02/17 02:36 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
I got my mallory 685 from Amazon for $165 during a clearance sale - same price as a normal 6a box at the time - less than half the going price now - Im a lucky [censored] sometimes
