1974 Satellite 318 #2280171
04/01/17 09:43 AM
04/01/17 09:43 AM
St Charles MO
70Coronet500Vert Offline OP
St Charles MO
I am going to put a FItech on this engine. It is a 2bbl. When I replace the manifold, does it have to be an EGR stlye since it is a 1974?
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 1974 Satellite 318 [Re: 70Coronet500Vert] #2280193
04/01/17 10:29 AM
04/01/17 10:29 AM
No as you will not be using (or want to use) the EGR function.
Re: 1974 Satellite 318 [Re: 70Coronet500Vert] #2280231
04/01/17 11:07 AM
04/01/17 11:07 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You have emissions inspections there?
Don't be the exception.
Re: 1974 Satellite 318 [Re: Supercuda] #2281317
04/03/17 01:29 AM
04/03/17 01:29 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
More importantly, Does your car have to pass emissions testing where you live. A 74 model year could predate emissions test requirements.
If you need to pass emissions testing, you will probably need the EGR. Gene
