1974 Rallye challenger Personality disorder #2279559
03/31/17 02:15 PM
03/31/17 02:15 PM
Tulsa
dubs chops Offline OP
Tulsa
Dubs Chops, post: 75938, member: 7467"]Disclaimer, I am going to tell a little bit of a story here at the front. if your only interested in pictures skip down below.
Well guys and gals, Last night I was able to bring home one of my dream cars. An E body challenger! Ever since I watched Kowalski Haul across the US as a kid I wanted a Dodge Challenger. To me it encompasses a sportier side of the muscle car genera.
3 days ago a 1974 challenger popped up on craigslist. I called the guy and talked to him for a bit and decided to go look and see if it was really "Rust Free". I drove the 30 minutes and when I arrived and saw the car I couldn't believe how clean it was. The car was supposedly in a garage since 1983 (The year I was born, Its a sign!) The vinyl top doesn't even show any fading or wear!
It Has a Dana 60 rear and 4link setup with Strange axles. Also has an 8pt cage but I may ditch it to be able to run full front interior. Also it is mini tubbed in the rear.
I didn't have the money that night and I asked if he would hold it for me for $1,000. I got a swift "NO" so that night I listed my pontoon boat and luck have it, I sold it the next day. I swiftly went home and got the car hauler and headed to his house.
here it is on the trailer coming home forever =]
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2279614
03/31/17 03:21 PM
03/31/17 03:21 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Congrats on bringing home one of your dream cars. What's the original color?
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2279656
03/31/17 04:18 PM
03/31/17 04:18 PM
Tulsa
Tulsa
no fender tag unfortunately. another way to tell? i'm going to say its that green color since all the jambs and under the door. not sure on the code.
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2280376
04/01/17 02:43 PM
04/01/17 02:43 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Congrats
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2280701
04/02/17 02:19 AM
04/02/17 02:19 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
That looks just like a 74 Challenger I used to own. I blew the motor up the same day the Space Shuttle Challenger blew up! It was a triple green car, and very nice! If it's the same car, I've got your original 318.....lol.
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2280941
04/02/17 03:43 PM
04/02/17 03:43 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Cool grab. Good luck with it. Keep us posted.
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2281086
04/02/17 07:52 PM
04/02/17 07:52 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
nice find!
1981 Dodge D150 360 auto
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2281230
04/02/17 11:24 PM
04/02/17 11:24 PM
New Mexico
Geo4K Offline
Geo4K  Offline
New Mexico
I'm glad the timing worked out for you and you were able to bring it home.
Re: 1974 Rallye challenger Personality disorder [Re: JDMopar] #2281782
04/03/17 07:18 PM
04/03/17 07:18 PM
Tulsa
Tulsa
No this was a 360 rallye car.
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2295554
04/28/17 11:54 AM
04/28/17 11:54 AM
Tulsa
Tulsa
The EFI tank and fuel pump from tanks inc, came in. Too bad I forgot to order the sending unit lol.
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2299298
05/05/17 12:51 AM
05/05/17 12:51 AM
Tulsa
Tulsa
Ok so tonight I tackled the fuel sending unit install, directions are a little confusing but I'll do my best to describe it here.
1st take out the 4 bolts holding the upper and lower portions and remove the lower metal bar.
Next measure the tank depth and devide by 2 then add 1/8" for the gasket. Make the center of the pivot on the reostat to the bottom of the gasket that measurement.
Then install the float rod to where the top of the float is equal to the bottom of the gasket.
(Here is a handy tip, The directions say to then cut the rod to length amd cut off the two ears on the bottom of the reostat. However with a pair of dikes you can snip off the remainder of the arm and bend the ears back and forth until theu break off without putting amy stress on the reostat. This will minimize metal shavings associated with a cutoff disc.)
Next I tested it with an ohm meter as per the directions. My son helped with the pictures since he happened to walk in the garage to tell me we were about to finish the Karate kid 2. He is 9 and I hope some of this runs off on him. wink
Last but not least. Pay attention to the bolt hole setup as it will only install 1 way. The holes are not evenly spaced. This had me scratching my head for a bit.
Hope to tackle the fuel pump soon and get this bad boy installed but I had to go finish the Karate kid with the fam tonight!
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2299500
05/05/17 12:59 PM
05/05/17 12:59 PM
Tulsa
Tulsa
Got the front part of the cage cut out so I could actually remove the dash and instruments. Cleaned up the guage cluster some and highlighted the faded redline numbers. Keep in mind this is not a concours restoration.
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2313561
05/30/17 02:17 PM
05/30/17 02:17 PM
Tulsa
Tulsa
Well Over the past couple of weeks I have been working on the trunk. I decided to clean it up before I installed the EFI tank. There was some surface rust underneath the trunk pan above the gas tank. I treated it with Eastwood Rust treatment that is supposed to turn rust into a paintable surface. I then undercoated it.
Then I went on to the trunk itself. Many hours with a wire wheel and I got to here.
Then hit it with self etching primer and new seam sealer
Then finished it off with Duplicolor Bed liner in a can
I have spent more time inside this Dang trunk then I ever thought I would.
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2313914
05/30/17 11:50 PM
05/30/17 11:50 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
That looks great though. From the first pic to the primer pic, it doesn't look like the same pan.
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2314530
06/01/17 12:18 PM
06/01/17 12:18 PM
Chicago
rocksmopar Offline
rocksmopar  Offline
Chicago
Looks like it was worth the time and effort...
Nice Work
Looking for affordable 72-74 Cuda parts
Re: 1974 Rallye challenger Personality disorder [Re: dubs chops] #2359677
08/25/17 03:02 PM
08/25/17 03:02 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Why cant I see pics?? frown
