AN fitting vs AN fitting?? #227900
02/17/09 05:07 PM
02/17/09 05:07 PM
California, USA
P
Phil Saran Offline OP
P
California, USA
Just wondering, is there any difference between
Russell vs Aerflow fittings. I need a -10 to
-10 connector and the Russell is about $21 from
Summit and the Aerflow (sp?) is $17. Can brands
be interchanged?
Phil Saran Parker, Colorado
Re: AN fitting vs AN fitting?? [Re: Phil Saran] #227901
02/17/09 05:12 PM
02/17/09 05:12 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Yes, all interchangable. Only diff in the cheaper ones is the anodizing. The summit/jegs brand seem to loose there luster after a year or two..
Gotcha!
Re: AN fitting vs AN fitting?? [Re: Phil Saran] #227902
02/17/09 05:13 PM
02/17/09 05:13 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
all AN fittings should be 37*
Sometimes I've heard of issues with mixing and matching hose ends/hose between brands.
Have you checked with airport spruce in Corona for fittings?
http://www.aircraftspruce.com/search/search.php
Stuff I found here was less than summit for the most part.
Re: AN fitting vs AN fitting?? [Re: RobX4406] #227903
02/17/09 05:22 PM
02/17/09 05:22 PM
Renton Washington
Triple Threat Offline
Renton Washington
http://www.aircraftspruce.com/menus/ha/an.html
direct link
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: AN fitting vs AN fitting?? [Re: Triple Threat] #227904
02/17/09 07:52 PM
02/17/09 07:52 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Those prices are good! Do they not do hose ends though?
68 Barracuda Formula S 340
Re: AN fitting vs AN fitting?? [Re: Phil Saran] #227905
02/17/09 08:49 PM
02/17/09 08:49 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
The mil spec fit will work, but different brands will have fit/finish diferences. For example, some interior i.d.'s will vary on a -10 X 3/8. It actually can be dramatic. I have also seen the same size fitting, that, one had a radiused entry, and one was blunt and small. Shop around, there is a difference in quality.
Re: AN fitting vs AN fitting?? [Re: Leigh] #227906
02/17/09 08:59 PM
02/17/09 08:59 PM
IN
ahy Offline
ahy  Offline
IN
I've mixed and matched Aeroquip, Russel and Summit without problem.
Re: AN fitting vs AN fitting?? [Re: ahy] #227907
02/17/09 10:29 PM
02/17/09 10:29 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
Low cost option link below. Steel rather than aluminum which adds some weight but they are more durable and the NPT versions won't gall when installed in aluminum.
http://www.robbmcperformance.com/products/fittings.html
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
