AN fitting vs AN fitting??
#227900
02/17/09 05:07 PM
02/17/09 05:07 PM
Posts: 396 California, USA
Phil Saran
California, USA
Just wondering, is there any difference between Russell vs Aerflow fittings. I need a -10 to -10 connector and the Russell is about $21 from Summit and the Aerflow (sp?) is $17. Can brands be interchanged?
Phil Saran
Parker, Colorado
Re: AN fitting vs AN fitting??
[Re: Phil Saran]
#227901
02/17/09 05:12 PM
02/17/09 05:12 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Yes, all interchangable. Only diff in the cheaper ones is the anodizing. The summit/jegs brand seem to loose there luster after a year or two.. Gotcha!
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Triple Threat]
#227904
02/17/09 07:52 PM
02/17/09 07:52 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
Those prices are good! Do they not do hose ends though?
68 Barracuda Formula S 340
[Re: Phil Saran]
#227905
02/17/09 08:49 PM
02/17/09 08:49 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
The mil spec fit will work, but different brands will have fit/finish diferences. For example, some interior i.d.'s will vary on a -10 X 3/8. It actually can be dramatic. I have also seen the same size fitting, that, one had a radiused entry, and one was blunt and small. Shop around, there is a difference in quality.
