Page 3 of 10 1 2 3 4 5 9 10
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278550
03/29/17 10:25 PM
03/29/17 10:25 PM
AndyF Offline OP
AndyF  Offline OP
This is the port match out of the box for the Indy 400-3. My guess is that you are leaving 5% of the power on the table if you run this intake as is. The port match isn't even close to be correct. If Indy would just spend 5 minutes and run a CNC pass around each port and matched it to their intake port it would save the little guy a bunch of time and effort.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278579
03/29/17 11:09 PM
03/29/17 11:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
2 sides to every argument......
The opposite view to "ootb intakes suck" is.... I've made 850hp with an ootb Indy 440-3.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278607
03/29/17 11:40 PM
03/29/17 11:40 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
picture is not great, but my 400-2 looks about the same as Andy's
Re: 470 dry sump engine on the dyno [Re: fast68plymouth] #2278611
03/29/17 11:46 PM
03/29/17 11:46 PM
Pattison Texas
Pattison Texas
Thats good to know,, WAY more power than my combination can make smile
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278644
03/30/17 12:25 AM
03/30/17 12:25 AM
Texas
RustyM Offline
RustyM  Offline
Texas
How much of what we see in these mismatches can be attributed to core shift and how much to manufacturers not matching intakes to heads?
Thanks for all the helpful info guys- appreciate all you share.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278680
03/30/17 01:05 AM
03/30/17 01:05 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I kind of like having a good port necked down a smidge at the opening so I can match it exactly to my heads, it makes the manifold a little more flexible as to what it will work with.
Re: 470 dry sump engine on the dyno [Re: RustyM] #2278822
03/30/17 12:32 PM
03/30/17 12:32 PM
AndyF Offline OP
AndyF  Offline OP
I consider it a missed opportunity by the mfgs to make extra money. If I sold CNC heads and I sold intake manifolds then the very least thing I would do is offer a CNC matching intake for an additional charge. The intake manifold already has to be in a machining center in order to surface the carb pad and drill and tap the bolts. Why not spend another 5 minutes of machine time and CNC the plenum for an extra $100 of revenue?
Indy will CNC their dual plan intake to MW size if you ask so they know how to do this work. No idea why they don't take the next step and provide a good port match on the rest of their intakes.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278987
03/30/17 05:15 PM
03/30/17 05:15 PM
Texas
RustyM Offline
RustyM  Offline
Texas
So air flow was 887 -890 cfm with 240 heads on that set up?
Be nice to know what it is with the 270 as well.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2279199
03/30/17 11:19 PM
03/30/17 11:19 PM
AndyF Offline OP
AndyF  Offline OP
Had some issues today but did manage to get some pulls done. One thing we figured out was that the billet valve covers are worth some horsepower so we switched over to them mid-day.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2279231
03/30/17 11:54 PM
03/30/17 11:54 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Well it's too early for April Fools so what's the deal?
Bulletproof valvetrain is distorting the head because of giant roller cam spring pressure so the billet valve covers act as a girdle?
I don't see any oil lines to them for spring coolers. work shruggy
Kevin
Re: 470 dry sump engine on the dyno [Re: Twostick] #2279237
03/31/17 12:00 AM
03/31/17 12:00 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Better sealing with a vacuum pump?
Re: 470 dry sump engine on the dyno [Re: AndyF] #2279248
03/31/17 12:08 AM
03/31/17 12:08 AM
Texas
RustyM Offline
RustyM  Offline
Texas
Probably that throttle return spring not matching the valve covers.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2279257
03/31/17 12:15 AM
03/31/17 12:15 AM
AndyF Offline OP
AndyF  Offline OP
Pan vacuum
Re: 470 dry sump engine on the dyno [Re: AndyF] #2279268
03/31/17 12:34 AM
03/31/17 12:34 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Originally Posted By AndyF
Pan vacuum
How much were you losing?
I would think the other covers would leak oil if it was that serious of a vacuum leak but I guess the vacuum would prevent that.
At atmospheric they probably sealed up fine to keep oil in so negative pressure distorted the clear tops?
Kevin
Re: 470 dry sump engine on the dyno [Re: AndyF] #2279315
03/31/17 01:35 AM
03/31/17 01:35 AM
AndyF Offline OP
AndyF  Offline OP
Picked up more than 10 hp by changing covers. No distortion, the vacuum just sucked in the gasket. We saw the pan vacuum drop so we started checking for a leak. Couldn't fix the valve cover in time so swapped on the billet valve covers and gained power.
Holding pan vacuum was one of the primary reason why I designed the billet valve covers in the first place. None of the other valve covers that I tried would seal up tight so I made my own.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2279363
03/31/17 06:17 AM
03/31/17 06:17 AM
Texas
RustyM Offline
RustyM  Offline
Texas
Please forgive a dumb question but, I won't know if I don't ask:
How does the pan vacuum make more power?
Better ring sealing?
Oil staying away from crank journals?
Re: 470 dry sump engine on the dyno [Re: AndyF] #2279393
03/31/17 09:37 AM
03/31/17 09:37 AM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Would be nice to see actual dyno sheets to back up all these claims of horse power changes. Just saying
Re: 470 dry sump engine on the dyno [Re: PETE@BESTMACHINE] #2279406
03/31/17 10:08 AM
03/31/17 10:08 AM
Minnesota
Coldart Offline
Coldart  Offline
Minnesota
Who's oil pan?
Looks nice, clean/sanitary package.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2279445
03/31/17 11:26 AM
03/31/17 11:26 AM
Texas
RustyM Offline
RustyM  Offline
Texas
You can see the pulls on you tube Pete.
Not as much data as a sheet but, the screen recording does help.
Re: 470 dry sump engine on the dyno [Re: Coldart] #2279513
03/31/17 12:50 PM
03/31/17 12:50 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted By Coldart
Who's oil pan?
Oil pan is one I had custom made. It is a billet pan.
