Re: 470 dry sump engine on the dyno
[Re: AndyF]
#2278100
03/29/17 12:31 AM
03/29/17 12:31 AM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
You should test the 270 heads with the same Wilson Modded M1 intake to see what it does even with the port mismatch. Since the intake Trick Flow recommends for these heads has a std. port window. I would be interested in the results of that test.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#2278106
03/29/17 12:39 AM
03/29/17 12:39 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
You should test the 270 heads with the same Wilson Modded M1 intake to see what it does even with the port mismatch. Since the intake Trick Flow recommends for these heads has a std. port window. I would be interested in the results of that test. I agree....... That really seems like the logical progression in the testing....... Especially since TF says that's what they used for their evaluation of the 270 heads.
[Re: sasquatch]
#2278122
03/29/17 01:12 AM
03/29/17 01:12 AM
fast68plymouth
So. Burlington, Vt.
Or a kind soul could let you borrow a nicely ported 400-3 intake..... Sure...... As the third one in the sequence.
[Re: fast68plymouth]
#2278126
03/29/17 01:16 AM
03/29/17 01:16 AM
Posts: 30,995 Oregon
AndyF
You should test the 270 heads with the same Wilson Modded M1 intake to see what it does even with the port mismatch. Since the intake Trick Flow recommends for these heads has a std. port window. I would be interested in the results of that test. I agree....... That really seems like the logical progression in the testing....... Especially since TF says that's what they used for their evaluation of the 270 heads. Regardless of what TF says, I do not think the Wilson intake will work with the 270 heads. It bolts on there okay but there is so little material around the ports that I don't think the gasket can properly seal. I looked at it and decided not to run it since I didn't want to suck in the gasket during a pull.
[Re: sasquatch]
#2278128
03/29/17 01:19 AM
03/29/17 01:19 AM
AndyF
Or a kind soul could let you borrow a nicely ported 400-3 intake..... Might be an option down the road. I'm testing this week and it would cost a ton to overnight an intake across the country. Depending on how things go I might do another round of testing down the road after I send this 400-3 off for porting. Might be nice to have another ported 400-3 on hand at that point to do a comparison.
[Re: AndyF]
#2278134
03/29/17 01:27 AM
03/29/17 01:27 AM
fast68plymouth
So. Burlington, Vt.
Does the TF intake cover the ports of the 270 heads better than the m1? If so, you could test that one on both sets of heads.
[Re: AndyF]
#2278137
03/29/17 01:40 AM
03/29/17 01:40 AM
fast68plymouth
So. Burlington, Vt.
Everyone has their own priorities when testing, but to my way of thinking....... To not do a back to back test where the only thing changed is the heads, really just muddies the waters about how the heads themselves compare.
Test the 240 heads with the TF intake and the 4150 carb of your choice..... Get a number. Put the intake and carb back on the 270 heads as the starting point..... Get a number. That's a back to back comparison without anything else skewing the results.
[Re: AndyF]
#2278239
03/29/17 11:22 AM
03/29/17 11:22 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Why not just test the 240 heads w/ a comparable out of the box manifold like you're gonna do w/ the 270 heads? Most people will not spend the big bucks like you did to have Wilson work their magic on an intake, so IMO you're giving the 240 heads an unfair advantage that will close the gap b/t the 2 heads.
[Re: an8sec70cuda]
#2278282
03/29/17 12:52 PM
03/29/17 12:52 PM
AndyF
Why not just test the 240 heads w/ a comparable out of the box manifold like you're gonna do w/ the 270 heads? Most people will not spend the big bucks like you did to have Wilson work their magic on an intake, so IMO you're giving the 240 heads an unfair advantage that will close the gap b/t the 2 heads. Out of the box intakes stink, I've already proven that to myself multiple times with the 240 heads. The Victor 383 sucked, the Mopar M1 sucked, The Trick Flow intake didn't completely suck but it wasn't very good until Hughes did the deep port match. The Wilson modified M1 is the best low deck intake I have so that is my starting point. I expect the Indy intake to be fairly poor but we'll find out shortly.
