Page 1 of 10 1 2 3 9 10
470 dry sump engine on the dyno #2278038
03/28/17 10:44 PM
03/28/17 10:44 PM
AndyF Online content OP
AndyF  Online Content OP
Got the new dry sump 470 up and running today. We broke it in and made a few pulls. It was making really nice power for being brand new, probably pick up a few more hp once everything gets sealed up properly.
First round of testing is with the Trick Flow 240 cc heads and then I'll switch over to the 270 cc heads for some back to back testing. I'll keep the same shortblock, cam, carb between heads but will have to change the intake manifold. I'm using the Wilson ported Mopar intake with the 240 heads but will use an as cast Indy 400-3 for the 270 tests. I'm sure the Indy intake will cost me some power but the 270 heads should more than make up for it.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278044
03/28/17 10:50 PM
03/28/17 10:50 PM
California USA
LowDeck451 Offline
LowDeck451  Offline
California USA
Beyond my pay grade but interesting nonetheless! Thanks for sharing!
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278061
03/28/17 11:23 PM
03/28/17 11:23 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Nice set up Andy!
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278067
03/28/17 11:34 PM
03/28/17 11:34 PM
The new low profile billet dry sump pan seems to be working just fine. The oil level in the tank doesn't drop much as RPM goes up so that means the oil is being pulled out of the engine at the correct rate. I need to take a video of the oil level before I know for sure how this new pan is working but so far it seems to be fine. Oil pressure climbs with RPM which is good news.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278084
03/29/17 12:04 AM
03/29/17 12:04 AM
Here is a link to a video of the console during a couple of the pulls we made today. Engine ran good, a leaky header gasket had us chasing our tails for a little while. When the header gasket leaks it makes the wideband sensors wonky. We thought we had a carb problem for a little bit until we figured out we just had a header gasket issue.
https://www.youtube.com/watch?v=uIUHd-2C1qY&feature=youtu.be
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278100
03/29/17 12:31 AM
03/29/17 12:31 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
You should test the 270 heads with the same Wilson Modded M1 intake to see what it does even with the port mismatch. Since the intake Trick Flow recommends for these heads has a std. port window. I would be interested in the results of that test.
The only Carbs I care about are under the hood!
Re: 470 dry sump engine on the dyno [Re: Azzkikrcuda] #2278106
03/29/17 12:39 AM
03/29/17 12:39 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I agree....... That really seems like the logical progression in the testing....... Especially since TF says that's what they used for their evaluation of the 270 heads.
Re: 470 dry sump engine on the dyno [Re: fast68plymouth] #2278114
03/29/17 01:02 AM
03/29/17 01:02 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Or a kind soul could let you borrow a nicely ported 400-3 intake.....
Re: 470 dry sump engine on the dyno [Re: sasquatch] #2278122
03/29/17 01:12 AM
03/29/17 01:12 AM
So. Burlington, Vt.
So. Burlington, Vt.
Sure...... As the third one in the sequence.
Re: 470 dry sump engine on the dyno [Re: fast68plymouth] #2278126
03/29/17 01:16 AM
03/29/17 01:16 AM
Regardless of what TF says, I do not think the Wilson intake will work with the 270 heads. It bolts on there okay but there is so little material around the ports that I don't think the gasket can properly seal. I looked at it and decided not to run it since I didn't want to suck in the gasket during a pull.
Re: 470 dry sump engine on the dyno [Re: sasquatch] #2278128
03/29/17 01:19 AM
03/29/17 01:19 AM
Might be an option down the road. I'm testing this week and it would cost a ton to overnight an intake across the country.
Depending on how things go I might do another round of testing down the road after I send this 400-3 off for porting. Might be nice to have another ported 400-3 on hand at that point to do a comparison.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278132
03/29/17 01:21 AM
03/29/17 01:21 AM
Here is a walk around the engine while it is warming. The engine oil is interesting. It is a 5w-30 break in oil that is super clear. You can see it spraying around on the rocker arms but it doesn't block the view.
https://www.youtube.com/watch?v=Hlw70nAao38
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278134
03/29/17 01:27 AM
03/29/17 01:27 AM
So. Burlington, Vt.
So. Burlington, Vt.
Does the TF intake cover the ports of the 270 heads better than the m1?
If so, you could test that one on both sets of heads.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278136
03/29/17 01:32 AM
03/29/17 01:32 AM
Yes, the TF has more material around the ports and it would probably seal up on the 270 heads. But it is a 4150 flange which throws another variable into the mix. I don't really want to do a 2 x 2 x 2 matrix of heads, intakes and carbs.
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278137
03/29/17 01:40 AM
03/29/17 01:40 AM
So. Burlington, Vt.
So. Burlington, Vt.
Everyone has their own priorities when testing, but to my way of thinking....... To not do a back to back test where the only thing changed is the heads, really just muddies the waters about how the heads themselves compare.
Test the 240 heads with the TF intake and the 4150 carb of your choice..... Get a number.
Put the intake and carb back on the 270 heads as the starting point..... Get a number.
That's a back to back comparison without anything else skewing the results.
Re: 470 dry sump engine on the dyno [Re: fast68plymouth] #2278201
03/29/17 09:20 AM
03/29/17 09:20 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
popcorn
Also, what are the dimensions of those dyno headers? scope
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278239
03/29/17 11:22 AM
03/29/17 11:22 AM
an8sec70cuda Offline
Why not just test the 240 heads w/ a comparable out of the box manifold like you're gonna do w/ the 270 heads?
Most people will not spend the big bucks like you did to have Wilson work their magic on an intake, so IMO you're giving the 240 heads an unfair advantage that will close the gap b/t the 2 heads.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 470 dry sump engine on the dyno [Re: AndyF] #2278276
03/29/17 12:37 PM
03/29/17 12:37 PM
Texas
RustyM Offline
RustyM  Offline
Texas
I think using the Trick Flow Intake on both set ups would accomplish some of that.
If adding compression and dry sump added 10 hp to the 240/ Wilson/ dominator configuration and we could see what the difference is with the trick flow Intake and 4150 Carb is- perhaps a pretty good baseline for seeing the difference the 270 heads make.
I really think the trick flow intake / 4150 Carb comparison is important and from there the
Other available intake/ carb combos .
Will a 337 intake make a good port match to the 270 heads .
Wondering what a 950 or 1000 cfm 4150 looks like on the 270 heads ?
Re: 470 dry sump engine on the dyno [Re: BradH] #2278280
03/29/17 12:46 PM
03/29/17 12:46 PM
Originally Posted By BradH
popcorn
2 x 32 with 3.5 collectors made by old Jere himself back around 2000 or so. They have held up well over the years. They were super expensive back then but I suppose it has been a good value over the years.
Re: 470 dry sump engine on the dyno [Re: an8sec70cuda] #2278282
03/29/17 12:52 PM
03/29/17 12:52 PM
Out of the box intakes stink, I've already proven that to myself multiple times with the 240 heads. The Victor 383 sucked, the Mopar M1 sucked, The Trick Flow intake didn't completely suck but it wasn't very good until Hughes did the deep port match. The Wilson modified M1 is the best low deck intake I have so that is my starting point. I expect the Indy intake to be fairly poor but we'll find out shortly.
