ok thanks found a product called k-seal anyone try that
Most any kind of stop leak will work just fine forever in your case. I have used Barrs many times and have used K seal one time on cracked head. The K seal is used very different than the Barrs leak, both will work just fine without plugging up your radiator.
I feel the K seal is for serious cracks/leaks and you would be better off using the Barrs leak for your situation.
One time when I was about 16-17 years old I had a 67-68 100 dollar Biscayne chevy with a 283 in it with a leaking radiator. One can of Barrs leak fixed it for about a month. Then another can fixed it for another month. Then the third can plugged up the radiator solid and the motor overheated and then the car went to the junkyard when that happened.
Many cooling parts I get for my big diesel work trucks comes with Barrs Leaks pills to put in the cooling system after the part replacement from the factory, so it can not be all that bad to use.
