I have looked for rubber ones without any success to go with the straps that I sell. The first issue is that they were not a serviced part from Mopar. Bad bushing, buy a new sway bar. Supposedly someone made a mold but is not going to ever make a run other that what he did for his own use. When I made the first straps, it was for a FF larger front sway bar for myself and I made my own bushings from rubber chunks, a band saw, a belt sander and drilled a larger diameter hole for the new bar. Black stuff everywhere! I just wanted a factory style mount. Good luck
