Re: Which thermostat on 400?
[Re: paddel]
#2277310
03/27/17 07:21 PM
03/27/17 07:21 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I always thought the car ran pretty hot, but the old stat could have been damaged for a long time. The thermostat only controls the warmup temperature, if the cooling system isn't capable of maintaining that temperature the car will run hotter than the thermostat setting. IOW, installing a 180° is no guarantee that it won't run hotter than that.
[Re: mikemee1331]
#2277467
03/28/17 12:43 AM
03/28/17 12:43 AM
RapidRobert
nothing less than 180. EDIT Unless a 1/4 mile dragger, then a 160.
[Re: paddel]
#2277704
03/28/17 02:17 PM
03/28/17 02:17 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
I run 160F in my street hot rods, they run hotter than that !
[Re: paddel]
#2277736
03/28/17 02:50 PM
03/28/17 02:50 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
180 is good for street.If its new then most run 195s bevause of computer controls and cleaner emmissions.I run 180 in my 440 and it never goes over 185 190 even when its 90 out.Rocky
Chrysler Firepower
[Re: Dave Hall]
#2277810
03/28/17 04:51 PM
03/28/17 04:51 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
The 195 will actually cool better because it allows the water to stay in the radiator longer. That violates several laws of thermodynamics. Thermal efficiency is 210. What? Do you mean that a typical four-stroke engine is most efficient at a coolant temp of 210? If so, why?
[Re: paddel]
#2277981
03/28/17 08:49 PM
03/28/17 08:49 PM
Posts: 2,262 Groveland, MA
SteveS
Groveland, MA
The rated temperature is the start to open.
Steve
Someday I'll have another C-body.
[Re: paddel]
#2278023
03/28/17 10:07 PM
03/28/17 10:07 PM
Posts: 2,467 Answering the call of the wild
ThermoQuad
The thermostat controls the minimum operating temperature only. Use a high flow thermostat. 60%water 40% coolant and a bottle of wetting agent. Today's gasoline is very different from 1970 and is designed to run in engines running 200-210 degrees. Thru the use of instrumentation[air-fuel meter] it is observed that when the operating temperature is below 195 degrees raw fuel will collect in the intake at idling & low rpm and burn off at cruise making the a-f rich then lean. The old iron runs great at 195 - 210. 210 is not hot, 220 is warm 230 is hot. Lot's of wives wagging their tales here.
[Re: Dave Hall]
#2278046
03/28/17 10:55 PM
03/28/17 10:55 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
Agreed. I'm just pointing out that the opposite can also be true. A 160 or running no thermostat doesn't necessarily make things cooler in the long run. Coolant that doesn't stay in the radiator long enough won't get cooled. OK, we've all heard that....but by that thinking, wouldn't the same coolant not stay in the engine long enough to pick up heat???
[Re: paddel]
#2278166
03/29/17 03:26 AM
03/29/17 03:26 AM
Posts: 19 Colorado springs, CO
Arominus
I'd run 195, double check the rest of your cooling system to make sure its working right.
1957 Desoto Firesweep 2dr 392/A518 builds in progress.
[Re: paddel]
#2278212
03/29/17 10:04 AM
03/29/17 10:04 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Any9one ever look at the math that calculate heat transfer efficiency?
NO
Of all the variables in that calculation TIME is not one of them.
The primary variable is heat differential.
The higher the difference the better the transfer. So please stop with the time in the block/radiator wives tale.
As for thermostat temps, that is the floor, not the ceiling. Running an engine cool is not a good thing for anything other than a dedicated race car.
