Underbody detail #2277203
03/27/17 03:37 PM
03/27/17 03:37 PM
gretna, Ne
O
oem6pak Offline OP
oem6pak  Offline OP
O
gretna, Ne
Is there a thread or link where I can find out the correct finish for all chassis components on a 69 abody, thanks
Pure Stock Rules
Re: Underbody detail [Re: oem6pak] #2277231
03/27/17 04:26 PM
03/27/17 04:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
in the restoration forum. ask the mods to move your post to there.
Re: Underbody detail [Re: mikemee1331] #2277541
03/28/17 04:57 AM
03/28/17 04:57 AM
gretna, Ne
O
oem6pak Offline OP
oem6pak  Offline OP
O
gretna, Ne
Ok,I'll try a different route,what are the correct finishes for these items Rearend housing-gloss black? Third member-natural finish(cast iron)? K frame-gloss black? Leaf springs-natural finish or flat black? Backing plates-flat black? Upper & lower control arm's-cast iron or flat black or gloss? Sway bar- Cast iron? Tierod ends-natural? Brake hub's-natural with red painted on top? Pitman arm -natural?
Trans crossmember-gloss or flat black? Thanks
Pure Stock Rules
Re: Underbody detail [Re: oem6pak] #2277595
03/28/17 10:24 AM
03/28/17 10:24 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Rear end - black lacquer gloss*
Third member - natural
K-frame - black lacquer gloss*
Leaf springs - depends on what was installed in your car, most are natural
Upper Control Arm - Natural
Lower Control Arm - Natural with most of it dipped in Kerosote
Sway bar - natural
Tie Rod Ends - natural
Brake Hub - Natural. Drums are painted red if equipped with road wheels and probably rare Kelsey Hayes wheels
Pitman Arm - Natural
Crossmember - black lacquer gloss*
*note the lacquer paint can vary a lot in gloss depending on numerous things. Most people dull it down. You have to go by your own car to determine how much.
Re: Underbody detail [Re: oem6pak] #2277663
03/28/17 01:04 PM
03/28/17 01:04 PM
gretna, Ne
O
oem6pak Offline OP
oem6pak  Offline OP
O
gretna, Ne
Thank you
Pure Stock Rules
Re: Underbody detail [Re: oem6pak] #2277742
03/28/17 03:02 PM
03/28/17 03:02 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Morty lower control arms are dipped in Cosmoline
http://www.restorick.com/proddetail.asp?prod=CosmoAero
Ron
Re: Underbody detail [Re: oem6pak] #2277840
03/28/17 05:26 PM
03/28/17 05:26 PM
gretna, Ne
O
oem6pak Offline OP
oem6pak  Offline OP
O
gretna, Ne
What about the lower shock mounts? Natural or ?
Pure Stock Rules
