1971 Duster 340 Charcoal canister ? #2277036
03/27/17 10:36 AM
03/27/17 10:36 AM
Massachusetts
RAII4-speed Offline OP
Massachusetts
Did all 1971 Duster 340s come with a charcoal canister?
Does anyone have pictures of the proper routing of one?
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277059
03/27/17 11:41 AM
03/27/17 11:41 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
71? I don't think any 71s came with a charcoal canister
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277062
03/27/17 11:45 AM
03/27/17 11:45 AM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
71 no. 72 yes.
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277218
03/27/17 04:07 PM
03/27/17 04:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If it had cali emissions it may have a charcoal canister ???
Re: 1971 Duster 340 Charcoal canister ? [Re: JohnRR] #2277239
03/27/17 04:38 PM
03/27/17 04:38 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No, none in 71 including California.
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277326
03/27/17 08:10 PM
03/27/17 08:10 PM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
Not to confuse things but my 71 340 Duster is a late build and has from the factory a 1972 fender apron. It has the indentation for the canister but the dimple holes for the bracket were never drilled. The line coming from under the car into the passenger side of the engine compartment also is upturned 90 degrees as opposed to the usual straight end that goes to the breather on the valve cover for 1971. No canisters for 1971.
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277550
03/28/17 05:55 AM
03/28/17 05:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Many 71's I believe is the year that the evap emissions from the fuel tank and carb went to the pass side valve cover breather and the evap fumes went into the crankcase. Then they were pulled into the eng and burnt through the PCV system. I dont remember if thats the way the 71 Duster 340 was but it may have been. I think most used the charcoal canister in 72. Ron
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277582
03/28/17 10:07 AM
03/28/17 10:07 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
CA cars had a NOX valve (on the pass side firewall, see pic) and the return vent line to the tank, 49 state cars did not. No charcoal canister until 1972.
The NOX valve had it's own wire harness extension, manual and auto trans versions were unique.
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277585
03/28/17 10:10 AM
03/28/17 10:10 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The valve shown here was only used on automatic versions.
Re: 1971 Duster 340 Charcoal canister ? [Re: ScottSmith_Harms] #2277586
03/28/17 10:11 AM
03/28/17 10:11 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
However I think it was only certain engines that got the NOX valve.
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277588
03/28/17 10:12 AM
03/28/17 10:12 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm pretty sure it was all engines Morty but I am only speaking to 71 340 A-body cars right now.
Automatic themoswitch used an angled bracket, manual was the smaller flat looking version (harness not installed on manual version pic).
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277601
03/28/17 10:46 AM
03/28/17 10:46 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Schematic for a 71 with CAP
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277602
03/28/17 10:53 AM
03/28/17 10:53 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Tank lines one before the protective shield was added and one after
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277604
03/28/17 10:55 AM
03/28/17 10:55 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I've noticed some small variables in the shields, not sure why
Re: 1971 Duster 340 Charcoal canister ? [Re: ScottSmith_Harms] #2277636
03/28/17 12:09 PM
03/28/17 12:09 PM
BDW Online content
BDW  Online Content
Any source for reasonably priced 3-nipple PVC breathers?
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277647
03/28/17 12:27 PM
03/28/17 12:27 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I see them at swap meets often. I probably have a few in the shed though mine are used originals.
Re: 1971 Duster 340 Charcoal canister ? [Re: RAII4-speed] #2277698
03/28/17 02:05 PM
03/28/17 02:05 PM
BDW Online content
BDW  Online Content
I don't care about originality, just need something functional
