65 plymouth motor mount brackets #2270631
03/16/17 04:46 PM
03/16/17 04:46 PM
British Columbia
Y
yellowgtx Offline OP
Y
British Columbia
Car had a 440 installed in it but was taken out when I bought it. All parts were there supposedly except motor. I did see the car with the 440 in it. The left side motor mount and bracket looks right or fits on anyway. The right hand side is or what should be does not bolt on or even look close. All the pictures I have tried to look at on the site have been removed. Anyone have good pictures of what the 65 B body big block brackets should look like. I did buy new mounts from summit that fit 65 and marked left and right. Help would be greatly appreciated
After almost 71 years I am on my last car. A 65 Plymouth Satellite straight axle altered wheel base car.
Re: 65 plymouth motor mount brackets [Re: yellowgtx] #2270640
03/16/17 05:09 PM
03/16/17 05:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: 65 plymouth motor mount brackets [Re: yellowgtx] #2270722
03/16/17 07:18 PM
03/16/17 07:18 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Here's mine. They're '64 but should be exactly the same as yours.
Driver's side.. extra bolts are a mod to eliminate the need for a torque strap.
Passenger's side.. no mods.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: 65 plymouth motor mount brackets [Re: Supercuda] #2276419
03/26/17 12:24 PM
03/26/17 12:24 PM
British Columbia
Y
Y
British Columbia
Thanks The right side I have is nothing like that. I guess I will order a set up. Thanks
Ron
Re: 65 plymouth motor mount brackets [Re: yellowgtx] #2276579
03/26/17 04:16 PM
03/26/17 04:16 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
If you use the Schumacher Creative Services mounts they won't move and you won't need a torque strap
http://www.hotrod.com/articles/mopp-0801-parts-department-engine-mounts/
I only bought the left mount for my '64 Polara
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 65 plymouth motor mount brackets [Re: yellowgtx] #2276606
03/26/17 04:55 PM
03/26/17 04:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 65s look like the ones posted.If you bought rubber mounts dont put much HP to them.Even ones from like 25 years ago i tore in a month.Went polys and have been in at least 12 years.Rocky
Chrysler Firepower
Re: 65 plymouth motor mount brackets [Re: yellowgtx] #2276701
03/26/17 07:42 PM
03/26/17 07:42 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Or... if you don't want to spend the cash you can do the simple mod I did and save $100.
alternative-to-the-venerable-torque-strap
Centerline
Re: 65 plymouth motor mount brackets [Re: yellowgtx] #2276778
03/26/17 10:07 PM
03/26/17 10:07 PM
64MAX Offline
64MAX  Offline
I may have one of those laying around upstairs in my garage. You can have it if you want to go that route.
Tom
