Re: Enclosed trailer wishlist??? [Re: MR_P_BODY] #2276497
03/26/17 02:26 PM
03/26/17 02:26 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Originally Posted By MR_P_BODY
Another thing I want is LED lights.. I am
changing all my exterior lights this year
since I have a light issue from when I bottomed
out last year and screwed up the wiring
wave
I did all my interior 12V lighting to LED last year, and what a difference...I don't even need 110v lighting anymore.
Re: Enclosed trailer wishlist??? [Re: dart440_72] #2276501
03/26/17 02:28 PM
03/26/17 02:28 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Locomotion had a good list. I forgot as a "wish" list:
* Bogey wheels or skids help keep from dragging the tail on hills/dips.
And maybe some RV type jacks at the rear corners so you can load and unload without having the truck connected.
Adding to wish list, built in air tank(s) and maybe even an air compressor. The "portable" air tank is another item that takes up space, and is either in the way, or stored in a hard to get at place.
Re: Enclosed trailer wishlist??? [Re: dart440_72] #2276576
03/26/17 04:14 PM
03/26/17 04:14 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Rather than install a winch, I bought a Warn Pullzall 24 v battery powered portable winch. It can be used on any of my trailers, or for many other pulling chores. I've been very happy with it. I just need to make sure the batteries are charged when I need it.
https://www.amazon.com/885005-PullzAll-C...rn+pullzall+24v
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Enclosed trailer wishlist??? [Re: dart440_72] #2276577
03/26/17 04:14 PM
03/26/17 04:14 PM
I would make sure it has the dovetail floor for easier loading and a good winch. The dove tail is probably standard now but it wasn't at one time shruggy
16 inch 6000 lb.+ axles and 8 lug wheels 16 inch truck tires up
Re: Enclosed trailer wishlist??? [Re: dart440_72] #2276643
03/26/17 05:54 PM
03/26/17 05:54 PM
CJD AUTOMOTIVE Offline
I'll throw in. I needed a trailer that I could take my dogs and wife comfortably. I have never been okay with leaving the car in the trailer and being inside a hotel. I am worried the whole time. The power awnings are the only way to go, as the legs are very high when extended and you can drive right under. I wanted a side ramp door to put a golf cart in as well. On top of that, wanted a slide, full living quarters, dual A/C, full size shower, fridge, etc...Oh and it had to be all aluminum. I like the spread axle look, but is so hard on tires in tight maneuvers, so no spread, but 17.5" tires. Took a LONG time to find a used one in my price range, but did actually find one. Not the color I wanted, but can't have everything!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Enclosed trailer wishlist??? [Re: 451Mopar] #2276651
03/26/17 06:17 PM
03/26/17 06:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've had a set of wheels/casters sitting here
for 2 years but keep forgetting to weld them on..
I have a compressor on my 43' with the lines
plumbed in.. I dont use the compressor all that
much.. but its there
wave
Re: Enclosed trailer wishlist??? [Re: MR_P_BODY] #2276656
03/26/17 06:31 PM
03/26/17 06:31 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I asked about bogey wheels and 3 different people said don't bother they hang to low and won't help out on my gravel driveway. They all suggested getting a piece of heavy wall pipe, cutting it in half, and welding it in areas that are issues. Mine being across the rear of my trailer because I back it down the hill and it levels off at the bottom.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Enclosed trailer wishlist??? [Re: pittsburghracer] #2276666
03/26/17 06:49 PM
03/26/17 06:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My 43' sits up higher than most so the boogies
do work.. when I tore up the wiring it was on
a very steep driveway coming out of a gas station
that I figured I could do but I was way wrong.. I
got so far then I had no choice but go forward and
tore up the left corner wires.. the boogies would
have worked then
wave
Re: Enclosed trailer wishlist??? [Re: CJD AUTOMOTIVE] #2276696
03/26/17 07:29 PM
03/26/17 07:29 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
CJD, that is a splendid trailer! How long is the garage vs. the living area?
Re: Enclosed trailer wishlist??? [Re: Hemi_Joel] #2276714
03/26/17 08:10 PM
03/26/17 08:10 PM
Thanks! It has a 22' garage and 26' living quarters. The generator is in the front, under the gooseneck, so it's clear without a gen cabinet. It has overheads down the sides and shallow fronts. I was a little concerned about the garage, but honestly, it's nicer to have the larger LQ's. I do have to store a few things in the front if I have the golf cart loaded, otherwise, plenty big enough. I am more than willing to "work with it" considering what I paid.
That's an old pic. Have since swapped out the TV's to flat screens and the sofa bed to twin recliners.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Enclosed trailer wishlist??? [Re: pittsburghracer] #2276717
03/26/17 08:18 PM
03/26/17 08:18 PM
Now 4 people. They hang too low and get torn off. The rolling pipe is the way to go and can be tucked up tight.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Enclosed trailer wishlist??? [Re: CJD AUTOMOTIVE] #2276744
03/26/17 09:16 PM
03/26/17 09:16 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have a 20 ft Haulmark, short but it fits in my driveway and my Dart fits fine. I like the idea of the interior led lights, Did you just change the 12V overhead bulbs? Part#s and were did you find them? Thanks
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Enclosed trailer wishlist??? [Re: CJD AUTOMOTIVE] #2276761
03/26/17 09:37 PM
03/26/17 09:37 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
Got a picture of this set up?
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Enclosed trailer wishlist??? [Re: dart440_72] #2277299
03/27/17 07:02 PM
03/27/17 07:02 PM
Medina, OH
dart440_72 Offline OP
Medina, OH
Thanks for all the words of wisdom!! This has been great!
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Enclosed trailer wishlist??? [Re: dart440_72] #2277699
03/28/17 02:06 PM
03/28/17 02:06 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Got them ( bulb # 1141 ) at Advance $20 a pair , Thanks for the idea!
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Enclosed trailer wishlist??? [Re: CJD AUTOMOTIVE] #2277731
03/28/17 02:44 PM
03/28/17 02:44 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Very nice. Anyplace I would go is 2-5 days and/or multiple events. I gave up on hotels looong ago. Motor homes are nice, but a truck with an LQ trailer makes sense for me. A vehicle that can be used for towing and also for transportation during the week or to leave the track if needed for supplies, go to dinner, whatever. The ATC units I've seen are super nice. Dealing with the DOT cops has become a big part of the equation over the last few years.
Re: Enclosed trailer wishlist??? [Re: CMcAllister] #2277762
03/28/17 03:37 PM
03/28/17 03:37 PM
Agreed. Wife likes those big toter homes, but not the most nimble thing for chasing a part, dinner, or grocery store! Besides, it would just sit. My pull truck is my DD. As far as DOT, mine is an RV cool , which is why I really like the windows in the garage area.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Enclosed trailer wishlist??? [Re: EWJ] #2277766
03/28/17 03:43 PM
03/28/17 03:43 PM
I don't, sorry. Trailer is up against the fence! I just used a scrap piece of pipe with another slid inside. The inside piece has brackets on each end, that captures the larger piece, and attaches to the frame. If it bottoms, the long pipe distributes the load down the length into the frame and rolls to reduce friction against the asphalt or concrete.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Enclosed trailer wishlist??? [Re: CJD AUTOMOTIVE] #2277923
03/28/17 07:34 PM
03/28/17 07:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On your set up is it riding on bearings or just loose
pipe.. I understand the ground clearance.. I have seen
that set up with loose fitting pipe.. I didnt care for
it due to rattling and making noise
wave
Re: Enclosed trailer wishlist??? [Re: MR_P_BODY] #2277946
03/28/17 08:05 PM
03/28/17 08:05 PM
Dragula Offline
Dragula  Offline
Well, the RV I had money down on, the guy just cancelled cause he wants his money next week.
I told him the house refi paperwork was all signed, but I still need 2-3 weeks to get thru everything...He ain't willing to wait that long and is sending my check back....I told him he was silly for thinking he is getting $30k from a guy he hasn't even met yet....
SOOOOOOO......I am back in the market looking at living quarter trailers and or whatever....What have you guys got?
