Paging DVW #2276636
03/26/17 05:33 PM
03/26/17 05:33 PM
Great Neck,LI,new york
hemi-itis Offline OP
Doug,I know you started with the same column as me.I would like to use your blueprint to modify mine.Did you any of the stock shaft or is your entire shaft CM tube,,,,,wait,that don't sound right blush
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Paging DVW [Re: hemi-itis] #2276655
03/26/17 06:23 PM
03/26/17 06:23 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The outer tube is original. It is shortened and has a plate welded on the end (like a large washer). I made the top housing that holds the bearing out of aluminum. It slides over the factory column tube and locks with a bolt. It's shown in the 2nd pic, it's painted and installed on the tube in the 3rd pic. Also the shaft bearing (generic 3/4" ball bearing) is mounted in the aluminum adapter. It is the only bearing, no bearing at the bottom of the tube. Shaft is 3/4" x .090" moly.
Doug
Re: Paging DVW [Re: hemi-itis] #2276665
03/26/17 06:44 PM
03/26/17 06:44 PM
I wish to keep the directionals for street driving.Will have to put my thinkin cap on,,,,,,
Re: Paging DVW [Re: hemi-itis] #2276681
03/26/17 07:12 PM
03/26/17 07:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think that I have a pic but I have all the
turn signal stuff still in mine but changed to moly
about 2" below the turn signal stuff but I had to
make up a bearing set up where the shaft comes out
of the column.. I'll look for a pic
wave
Re: Paging DVW [Re: hemi-itis] #2276763
03/26/17 09:38 PM
03/26/17 09:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Put a toggle for the TS switch on the dash. I love my removable wheel.
Doug
Re: Paging DVW [Re: dvw] #2276810
03/26/17 10:56 PM
03/26/17 10:56 PM
I love yours too whistling The toggle thing would be a gaggle of wires.When I get the column out I will figure that out,,,,,,,,, shruggy
