Re: Leaf springs, natural or painted?
[Re: BADBEE]
#227660
02/17/09 10:47 AM
02/17/09 10:47 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
depends on the year... From what I've gathered on here, more often than not, '68 and earlier were natural whereas '69 and later painted black..
I'm sure someone else will have input...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: BADBEE]
#227663
02/17/09 03:05 PM
02/17/09 03:05 PM
hemi68charger
Houston, Tx
Here are mine.. Since it's a '68, I left them natural. Rebuilt the spring assembly with the total rebuild kits you can get. I Matte cleared them prior to installation to retain the natural look while maintaining corrosion control. If painted, I believe the complete assembled spring, minus the hangers and shackle of course, is painted black to include the clamps..
[Re: Slim Smitty]
#227666
02/18/09 08:50 AM
02/18/09 08:50 AM
Another thing to be concerned about when using clear on bare metal parts,is that sooner or later rust will form under the clear coat.Ask me and many others how we know!
#227667
02/18/09 08:55 AM
02/18/09 08:55 AM
hemi68charger
Houston, Tx
Not to doubt you since I used it, but how-so from a curious point of view?
[Re: Slim Smitty]
#227668
02/18/09 08:57 AM
02/18/09 08:57 AM
hemi68charger
Houston, Tx
What brand of clear did you use? I've used Eastwood's satin clear on a few parts, it really made them look satin and not natural. I'm also concerned it will get white marks if it's scratched. Just wondering if you're using something different. If the springs are cleared in that pic, they look pretty good.
I used this.. You usually can pick some up at Hobby Lobby or order it online, google Krylon Matte
[Re: hemi68charger]
#227669
02/18/09 10:27 AM
02/18/09 10:27 AM
One of the resto shops told me that moisture gets trapped under the aerosol type clear coats and eventually will develope flash/surface rust on the part.He told me this after I had sprayed some of my parts and sure enough after a few months the rust appeared.Of course it was trapped under the clear coat so I had to strip off the clear coat to get to the rust.Now he also told me that if it is sprayed with a gun you're less likely to have this problem.I hope you guys don't run into this problem,but me and a few of my other buddies did.
[Re: THESHAKERPROJECT]
#227672
02/18/09 01:42 PM
02/18/09 01:42 PM
Posts: 6,519 Buffalo, NY U.S.A.
MrNormsTA
Buffalo, NY U.S.A.
Good post.
Many parts were natural bare metal. You have 3 choices when doing a resto, strip and leave bare, strip and clear, or strip and try to use a paint that matches the original metal color. Although I did a few small items, clear just doesn't look right IMO.
I tried to stay away from clear on large parts, but am not doing an OE resto, so many of my parts I primed and used metal simulated paints, for example springs, spring hangers, front suspension, driveshaft, brake and pedal assemblies. Very happy with some of the Eastwood metal paint products.
On the springs, I have heard both ways were found, so I went with painted black with natural bands.
Rick.
[Re: MrNormsTA]
#227674
02/18/09 01:52 PM
02/18/09 01:52 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I'm sure there are different ways certain cars were done depending on model, year and plant. I had thought that black was correct on my '70 Lynch Rd. 'Bee and the clamps, springs and front hangers were all together and painted gloss black at once. Oh well, If I'm wrong, it's not like the rest of the car is 100% correct! Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
