MSD6 Antique ? #2276550
03/26/17 03:39 PM
03/26/17 03:39 PM
A727Tflite Offline OP
Have a MSD6 - called MSD and they can't even tell me, and i can't find this in any of the older catalogs I have. I have the normal 5 pin Mopar plug on one end - then a wire and also a female on the other end. The female says Batt. Just wondering if this is correct or ? Will post pics soon.
Re: MSD6 Antique ? [Re: A727Tflite] #2276555
03/26/17 03:43 PM
03/26/17 03:43 PM
nuther pic of the MSD6
Re: MSD6 Antique ? [Re: A727Tflite] #2276572
03/26/17 04:08 PM
03/26/17 04:08 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Where it says battery I'm think that is where the tach wire goes I could be wrong but that's the same one in my brothers car
Re: MSD6 Antique ? [Re: scottb] #2276589
03/26/17 04:35 PM
03/26/17 04:35 PM
That's what i thought too. I hate seeing smoke after installing electrical parts. Your Bro has the same exact MSD6 with the 5 pin connector on one end and the female and the wire on the other end?
Re: MSD6 Antique ? [Re: A727Tflite] #2276625
03/26/17 05:22 PM
03/26/17 05:22 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Wait for Cab, he will know this box.
Re: MSD6 Antique ? [Re: A727Tflite] #2276662
03/26/17 06:41 PM
03/26/17 06:41 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Any pictures of the other plug end
Re: MSD6 Antique ? [Re: A727Tflite] #2276676
03/26/17 07:04 PM
03/26/17 07:04 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
That sounds like the old MSD 6c. The 5 pin end let you plug the box directly into the factory wiring(if you had electronic ignition). The spade end should be for the tach if I remember right.
Ok
Re: MSD6 Antique ? [Re: A727Tflite] #2276677
03/26/17 07:07 PM
03/26/17 07:07 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I used to have a couple of MSD 6C boxes with the 5pin connectors. They had a #12 black bat neg -,#12 red bat pos +, and a tach connection on one end and the Chry. 5 pin on the other end. They used no ballast resistor
If looking at the 5 pin going clock wise (12 o'clock)ign hot, mag pick up neg-, mag pick up pos+, coil pos, coil neg.
"Just a Bracket car dressed up like a streetcar"
Re: MSD6 Antique ? [Re: A727Tflite] #2276693
03/26/17 07:26 PM
03/26/17 07:26 PM
The black wire shown with the blue tape has an eyelet on it. I know the later MSD6 has dedicated + and - wires on on end and the normal connectors on the other. This one has the 5 pin and what is shown in the second image. I knew of the 6C but for the life of me cannot find a schematic of it.
Re: MSD6 Antique ? [Re: A727Tflite] #2276697
03/26/17 07:34 PM
03/26/17 07:34 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
That should be the ground. The spade above the wire is for the tach. I used to have the schematic on the 6c. I will check and see if I still have one.
Ok
Re: MSD6 Antique ? [Re: A727Tflite] #2276702
03/26/17 07:42 PM
03/26/17 07:42 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Wow I had a 6C in the late 70's in my 72 GTX
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: MSD6 Antique ? [Re: A727Tflite] #2276711
03/26/17 08:02 PM
03/26/17 08:02 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Here is what I came up with. Its for a 7c the connections are in different locations than the 6c but should still be similar. Hope it helps. [img:left]http://[/img]
Ok
Re: MSD6 Antique ? [Re: A727Tflite] #2276716
03/26/17 08:14 PM
03/26/17 08:14 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Have this photo. I have a msd 6c that i bought in 1978. It still works and have instructions also.
Tony
70 AARCuda Vitamin C
Re: MSD6 Antique ? [Re: A727Tflite] #2276844
03/26/17 11:32 PM
03/26/17 11:32 PM
70AARcuda - thanks. But to clarify since you have a 6C - does your module have the female and a black wire on the other end from this 5 pin connector? Thanks to all that have replied. As for why I am trying to use this antique - it was a good friends unit who passed away. It worked on his car and he had it as a back up unit. We had a joke going about not throwing good stuff away - and in general not throwing anything away. So I want to use this thing so he can "ride" around with me as I cruise the places we used to cruise back in the day. Silly? - yep.
Re: MSD6 Antique ? [Re: A727Tflite] #2276847
03/26/17 11:36 PM
03/26/17 11:36 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
It is in the shop...Will check tomorrow.
Tony
Re: MSD6 Antique ? [Re: A727Tflite] #2278598
03/29/17 11:31 PM
03/29/17 11:31 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
It has the red lead for the battery and the black negative wire on the other end from the 5 pin connector...plus it has the tach output too
Tony
Re: MSD6 Antique ? [Re: A727Tflite] #2278637
03/30/17 12:13 AM
03/30/17 12:13 AM
Thanks - sounds like my unit is a tad different than most - I had a 6 that had the dedicated + and - plus the 5 pin - this relic has just the black ( I assume - ) on the end plus a tach plug.
