727 Leaking Fluid At Cover Plate
#2276079
03/25/17 05:26 PM
03/25/17 05:26 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
The first couple of startups this season I did not see any leaks. Today I pulled the car in/out of the garage a few times (spring cleaning garage) and I noticed a small puddle of trans fluid. It is coming out of the lower cover. I checked the fluid level and it showed apx 1/4" below the full line (in N engine warm and went through the gears before checking). Rebuilt trans 3 years ago with apx 1500 miles or so since. Any suggestions on what to look for?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: 727 Leaking Fluid At Cover Plate
[Re: YO7_A66]
#2276082
03/25/17 05:31 PM
03/25/17 05:31 PM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Lower cover? The plate on the front of the bell housing? That covers the front/bottom of the torque converter? Sounds like the front seal has gone bad.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2276099
03/25/17 06:14 PM
03/25/17 06:14 PM
YO7_A66
Indiana
Yes, that one. Crapt! I remember wiping off some fluid there last fall a few times. Today I found a couple of small puddles (quarter size) after it shut down a few times. Thanks
[Re: A727Tflite]
#2276149
03/25/17 08:13 PM
03/25/17 08:13 PM
YO7_A66
Indiana
Thank you! I will try to diagnose tomorrow.
[Re: bobby66]
#2276199
03/25/17 10:12 PM
03/25/17 10:12 PM
YO7_A66
Indiana
I ran my hands up and around both sides and they were dry. It was dripping out of the cover. I was working on the choke setup so I started it up two more times after I wiped it down then parked it to watch for leaks. But I just went out and looked under the car and the floor was completely dry. So I will get it back in the air tomorrow and dig further in. Thanks again.
[Re: bobby66]
#2276268
03/26/17 12:36 AM
03/26/17 12:36 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Could it be the o-ring on the filler tube? Much easier to fix than dropping the trans. That would result in it dripping from the pan. Not the inspection cover. Tranman has the right approach.
[Re: Morty426]
#2276535
03/26/17 03:21 PM
03/26/17 03:21 PM
YO7_A66
Indiana
Update: I removed the cover and I could not get my fingers in far enough to check out the back side of the TC. I sprayed the inside of bell with brake cleaner and wiped it clean. I ran the engine for 5 minutes on fast idle (1300rpms) with tranny in P. No leaks. I then let it set for 10 minutes with no leaks and inside of bell was dry. I then ran the engine for 10 minutes on fast idle with tranny in N. No leaks. I then let it set for 10 minutes with no leaks and inside of bell was dry. I will not get a chance to drive it today due to weather.
I did drive it up and down the drive yesterday just to get the fluid moving before I pulled it in. It is strange that yesterday it left 3 quarter size puddles and today it is dry. Thanks!!
[Re: YO7_A66]
#2276833
03/26/17 11:24 PM
03/26/17 11:24 PM
Posts: 3,076 Michigan
A727Tflite
Hopefully it healed itself. Make sure you check the fluid level warm and in neutral - and we assume you have the correct stick for the tube.
Did you back it out of the garage or was it nose out and you drove it out when it leaked?
[Re: A727Tflite]
#2277090
03/27/17 12:19 PM
03/27/17 12:19 PM
YO7_A66
Indiana
Thank you very much Transman! I will keep an eye on it during my first couple of drives to make sure all is good.
[Re: A727Tflite]
#2277151
03/27/17 02:00 PM
03/27/17 02:00 PM
YO7_A66
Indiana
It is not my bench. But my guess is, you two know each other. (Rick Allison)
