Victor or Trick Flow Intake for RB? #2275934
03/25/17 12:52 PM
03/25/17 12:52 PM
North Central, Indiana
Roughbird72 Offline OP
I've been accumulating parts for a 463" RB and I already have the TF 240s. Has anyone seen/done a dyno comparison between the two? shruggy
72 Plymouth Roadrunner 11.08@123.25
Re: Victor or Trick Flow Intake for RB? [Re: Roughbird72] #2275965
03/25/17 01:50 PM
03/25/17 01:50 PM
AndyF Offline
AndyF  Offline
Out of the box the Trick Flow intake will make more power on the dyno than the Victor. The Victor has a small plenum and the casting quality isn't as good as the Trick Flow.
If you want to pick up a little more power then buy the Trick Flow intake from Hughes Engines and ask them to do the deep port match work. That will free up another 10 hp or so.
Re: Victor or Trick Flow Intake for RB? [Re: Roughbird72] #2276091
03/25/17 05:56 PM
03/25/17 05:56 PM
Thanks Andy!
Jeff
Re: Victor or Trick Flow Intake for RB? [Re: Roughbird72] #2276116
03/25/17 06:53 PM
03/25/17 06:53 PM
AndyF Offline
AndyF  Offline
The port matched Trick Flow with a big 1050-AN carb from QuickFuel has been working great on my 470. Makes almost as much power as the ultra spendy Wilson intake with a Dominator carb.
Re: Victor or Trick Flow Intake for RB? [Re: Roughbird72] #2276121
03/25/17 06:56 PM
03/25/17 06:56 PM
