help! #2275596
03/24/17 09:33 PM
03/24/17 09:33 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
hi guys!
i have a 08 ram with 5.7 hemi..
i got a water leak! it in the bellhousing area, how differcult
to change out freeze plugs, are is it leaking somewhere esle?
i'm really at my end wits with my truck.. i just dont have the money to work on it right now... got to change my waterpump out im thinking my heatercore is leaking.. i need help!!!!
Re: help! [Re: BigTerry] #2275613
03/24/17 10:06 PM
03/24/17 10:06 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Wrong forum.
Try the truck page
Re: help! [Re: BigTerry] #2275693
03/25/17 12:13 AM
03/25/17 12:13 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Are you sure it's inside the bellhousing area. Hemi's have 2 metal heater tubes that run from front to back of the engine, to the rubber hoses. Maybe the tubes rotted out or the rubber hoses are leaking.
[image][/image]
Re: help! [Re: BigTerry] #2275706
03/25/17 12:48 AM
03/25/17 12:48 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Borrow your wife's hand mirror and see what you can see of the back of the engine.
Re: help! [Re: sgcuda] #2275852
03/25/17 10:40 AM
03/25/17 10:40 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
Well coolant is leaking from between the engine and trans area..if the heaterline are running close to that area then maybe that the problem.. I will check that out more closely! Thank You i didn't think about!
Re: help! [Re: BigTerry] #2276105
03/25/17 06:30 PM
03/25/17 06:30 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
if your waterpump is leaking the fan will blow coolant all over the place.i thought a freeze plug went bad on the back of a 4.0 jeep ended up being the pump
Re: help! [Re: BigTerry] #2276496
03/26/17 02:26 PM
03/26/17 02:26 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
which heater line is the inlet?
Terry Sansom
Re: help! [Re: d-150] #2276504
03/26/17 02:31 PM
03/26/17 02:31 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
i been getting puddles in front of the truck sometime not..
the day before i had a puddle just under the engine.. that has confuse me since i seen no freeze plug on pictures of this 5.7 in the bellhousing area.. waterpump hasn't shown any water trail till the last couple of week so i'm sure it need to be replace..truck got a 150000 miles on her..
