What is this transmission?
#2275420
03/24/17 03:15 PM
03/24/17 03:15 PM
Posts: 2,512 God's Country Maryland
GODSCOUNTRY340
Doesn't look anything like a 727 or 904. Body bolts to the bell.
Re: What is this transmission?
[Re: GODSCOUNTRY340]
#2275424
03/24/17 03:27 PM
03/24/17 03:27 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It's an iron Powerflite 2-speed from the fifties.
#2275444
03/24/17 04:08 PM
03/24/17 04:08 PM
Posts: 19 Colorado springs, CO
Arominus
Yup, looks like am air cooled powerflight 2 speed, you'll need an adapter plate to put anything else on that motor. You will use the same adapter that the chrysler 331/354/392 hemis use for whatever transmission you want to put on it.
If you decide to use the powerflight, its got ratios of 1.72 and 1.00. You can add take offs to run lines up to a trans cooler (i would) the torque converter has fins on it that help cool it as well. Thats why the bellhousing has those mesh covers over the openings.
1956 315 hemi? a 57 325 hemi would likely have a torqueflight on it.
1957 Desoto Firesweep 2dr 392/A518 builds in progress.
#2275484
03/24/17 06:01 PM
03/24/17 06:01 PM
GODSCOUNTRY340
I'm in the process of taking this apart right now, how the heck does the torque convertor un-bolt? I have the trans separated from the engine but don't see any kind of a flex plate or flywheel for un-bolting it from the crank. Does it have to come out with the crankshaft? I'm not going to use the trans, is there any market for them? The engine is a '55 270 Hemi. I plan on it ending up in my '54 Flat fender Powerwagon.
#2275517
03/24/17 06:54 PM
03/24/17 06:54 PM
John_Kunkel
Rio Linda, CA
The converter has eight studs that go through unthreaded holes in the crank flange with nuts on the front of the flange.
[Re: John_Kunkel]
#2275520
03/24/17 06:58 PM
03/24/17 06:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Just to be clear, there is no flexplate, just the studs poking out the nose of the converter thru the crank. You can kinda see it in the pic at Allpar http://www.allpar.com/mopar/powerflite.html
[Re: Arominus]
#2275558
03/24/17 08:13 PM
03/24/17 08:13 PM
GODSCOUNTRY340
Okay, I see them. Looks like there's not much room to get the nuts off, how hard are they to remove?
#2275583
03/24/17 09:01 PM
03/24/17 09:01 PM
Supercuda
About to go away
About to go away
up yours
Thanks everyone. Looks like I know what I'll be doing tomorrow. Exercising your vocabulary of curse words no doubt.
[Re: Supercuda]
#2276790
03/26/17 10:24 PM
03/26/17 10:24 PM
Posts: 5,105 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Thanks everyone. Looks like I know what I'll be doing tomorrow. Exercising your vocabulary of curse words no doubt. I can tell you from experience his does not need exercising...
...FAFO...
[Re: Cab_Burge]
#2277177
03/27/17 02:56 PM
03/27/17 02:56 PM
GODSCOUNTRY340
Luck finally came my way, once I broke the nuts loose they all came out with my fingers and believe it or not no curse words were flying around my garage. Even I can't believe that one. The Powerwagon is a stick but I'm going to attempt to adapt it to an '87 Powerwagon auto trans. I've been told the adapters for the 331 & 354 Hemi will fit this 270 Hemi. Skicker, I learned all my bad language from you! Ha, Ha.
