Polyester primer... anyone use it over bare metal?? #227535
02/17/09 12:26 AM
02/17/09 12:26 AM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
Anyone use polyester primer over bare metal? I've been looking at the Evercoat Slick Sand polyester primer and thinking it might be perfect for me. I'm doing a repaint of a daily driver type car that's in overall good shape, but its hood and front fenders are pitted to hell from stone chips. Looks like someone drove this thing behind a gravel truck or something.
Looks to me like the slick sand should be right up my alley. So I would be spraying it mostly over existing scuffed OEM paint with some small bare metal areas. No doubt there will be some small bare metal spots where I take it all the way down with the sander, but will probably 99% be scuffed OEM paint.
The P sheets for the paint I plan to use say it can go right over this stuff and the P's for the slick sand say to go right over metal without an etch or sealer. Sounds almost too easy...?
Surely some of you guys have experience with this stuff.
Re: Polyester primer... anyone use it over bare metal?? [Re: DaytonaTurbo] #227536
02/17/09 12:46 AM
02/17/09 12:46 AM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
Yes we used to at the shop I helped out at{freinds place} used it after stripng cars to bare metal. but we sanded it with 80 first. so i giess it had a chemical and machnical adheasion.
Just don't leave it out to get wet since ther is no epoxy under it to seal the metal 100%
Nothing at the shop got epoxy ecept a few thongs we did for ourself that was going to be a long long time before it was 100% done
Jobs came in and went right back out and never sat outside in rain or anything
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Polyester primer... anyone use it over bare metal?? [Re: DaytonaTurbo] #227537
02/17/09 12:56 AM
02/17/09 12:56 AM
South Dakota
hotairballoonpilot Online work
hotairballoonpilot  Online Work
South Dakota
so you know PPG's shopline brand sands ike a rock by hand but works with an air sander good. Just watch the build up. I got it to thick on a 32 buick on some body lines and had problems with it bridging over that small area and then cracking. like what was said DON'T GET IT WET!
Contact Me about AMD Prices
Re: Polyester primer... anyone use it over bare metal?? [Re: hotairballoonpilot] #227538
02/17/09 01:44 AM
02/17/09 01:44 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I used it once...It takes sand scatch swelling to a different level...
Re: Polyester primer... anyone use it over bare metal?? [Re: 1_WILD_RT] #227539
02/17/09 10:30 AM
02/17/09 10:30 AM
okla.
O
okie Offline
okie  Offline
O
okla.
I'm fixing to use some of it so I will know later how it works. The guy at the paint store said it was good. There is a story in the new Hot Rodding mag. about using it so it seems to be an accepted way to do it. i do know that the epoxey primer gets super hard and it is a pain to get it sanded but I usually coat everyhing with it first so maybe i have't messed up, I'll find out soon.
Re: Polyester primer... anyone use it over bare metal?? [Re: DaytonaTurbo] #227540
02/17/09 11:00 AM
02/17/09 11:00 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've used it over epoxy primer for a solid base. I don't think it's best without a good sealer under it.
Re: Polyester primer... anyone use it over bare metal?? [Re: DaytonaTurbo] #227541
02/17/09 11:50 AM
02/17/09 11:50 AM
Jacksonville Florida
elitecustombody Offline
bad idea, if you have just a few small sandes thru on a corner or edge it'll fly, but I wouldn't apply it over bigger spots, use rattle can etching primer on those spots,scuff with brown pad and then it'll be fine, non of Evercoat polyester primers bond well to bare metal, no matter what the label on the can says,and if you have some body panels completely down to bare metal, I'd suggest using epoxy primer first, for a piece of mind, it's worth to spend couple hundred bucks ,especially if you plan on keeping the car for a while
Re: Polyester primer... anyone use it over bare metal?? [Re: elitecustombody] #227542
02/17/09 01:19 PM
02/17/09 01:19 PM
Do you find they do not bond well on bare metal with just a chemical bond or with a machincal one?
We always striped a car with aircraft then cleaned it well. then Ran a DA over everthing with 80 so it had both?
Just wondering if it was just a problem for you with a chemical bond or both?
Remember "My poor car" was done in a non resto shop. They mostly did insurance in and out jobs. I helped him out plenty on stuff and my car was done here and there when time was free, also used left over evercoat ultamite primer when some was left over from something else. and the paint was cheap R-M limco supreme. I have 800 in the whole thing.
My next car will be done right I hope.
Re: Polyester primer... anyone use it over bare metal?? [Re: 340SIX] #227543
02/17/09 03:44 PM
02/17/09 03:44 PM
It was years ago,thank God it was my own Suburban, I molded ABS flares to new fenders,the fenders were grinded and sanded with 80 grit, in about 2 months I started seeing blisters,short strand fiberglass has stuck pretty well to steel,but all bare metal areas that were covered with Evercoat FeatherFill or SlickSand,can't remeber which one,has lifted, so since then I never use polyester primer over bare metal,there is no mechanical or chemical adhesion,
Re: Polyester primer... anyone use it over bare metal?? [Re: elitecustombody] #227544
02/17/09 05:51 PM
02/17/09 05:51 PM
Manitoba, Canada
Manitoba, Canada
If I have some small bare metal areas from going too far with the sander, ie a 2" diameter circle, can I use an etching primer then hit it with the polyester primer?
Will it stick well enough for small areas like that? Or should I just epoxy those areas while I'm at it before spraying on the polyester?
Re: Polyester primer... anyone use it over bare metal?? [Re: DaytonaTurbo] #227545
02/17/09 06:09 PM
02/17/09 06:09 PM
Cincinnati, Ohio
Cincinnati, Ohio
Your better off sealing the area with epoxy primer to give the poly fill a good foundation.
Re: Polyester primer... anyone use it over bare metal?? [Re: DaytonaTurbo] #227546
02/17/09 06:55 PM
02/17/09 06:55 PM
that's what etching primer in rattle can is for and will do just fine, no need to get all the mess started with epoxy for a few small spots
Re: Polyester primer... anyone use it over bare metal? [Re: 340SIX] #227547
02/17/09 07:19 PM
02/17/09 07:19 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That sounds painfull...
Re: Polyester primer... anyone use it over bare metal? [Re: Lefty] #227548
02/17/09 07:35 PM
02/17/09 07:35 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Be careful putting polyester primer over etching primer also. Evercoat Featherfill G2 is ok but slick sand and regular feather cant be used over etch primer.
Re: Polyester primer... anyone use it over bare metal? [Re: AdamR] #227549
02/17/09 08:54 PM
02/17/09 08:54 PM
Manitoba, Canada
Manitoba, Canada
Yeah I just looked up the P sheets for PPG's omni brand polyester and they say specifically NOT to use it directly over etching primer. The info for the slick sand doesn't say not to use it, but it doesn't say to use it over etching either so that's indication enough. The sheets for the featherfill G2 say you can use it right over etching but it'll lengthen drying time.
Re: Polyester primer... anyone use it over bare metal? [Re: DaytonaTurbo] #227550
02/17/09 11:56 PM
02/17/09 11:56 PM
don't forget to roughen it up before spraying polyester
Re: Polyester primer... anyone use it over bare metal? [Re: Lefty] #227551
02/18/09 12:28 AM
02/18/09 12:28 AM
That my friend was a typo the O is right next to the I
Re: Polyester primer... anyone use it over bare metal? [Re: 340SIX] #227552
02/18/09 01:47 PM
02/18/09 01:47 PM
Manitoba, Canada
Manitoba, Canada
Really? I thought maybe that explained the pink...
Re: Polyester primer... anyone use it over bare metal? [Re: DaytonaTurbo] #227553
02/18/09 02:44 PM
02/18/09 02:44 PM
Why would you prime or paint a Thong?
Re: Polyester primer... anyone use it over bare metal? [Re: 340SIX] #227554
02/18/09 05:10 PM
02/18/09 05:10 PM
Manitoba, Canada
Manitoba, Canada
You mean you haven't seen pics of girls with the painted on bikinis...?
