LSD for Autocross?
#2263888
03/05/17 07:41 PM
03/05/17 07:41 PM
Posts: 200 Colorado
Bob J
Colorado
What is the best LSD for Autocross? I have a Power lok out of my 68 that I can rebuild and how well will that work? Does anybody know the ratio on a power lok vs what else is out there?
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
Re: LSD for Autocross?
[Re: Bob J]
#2264290
03/06/17 01:59 PM
03/06/17 01:59 PM
Posts: 350 central IL
myduster360
central IL
I'm definitely considering a helical diff like the Eaton TrueTrac, Quaife, Torsen,ect.
The fact that they always transmit torque to the wheel with the MOST traction(instead of the least) is what sets that design apart. Seems it would work great for corner exit.
1972 Swinger 3.6L Pentastar Diablo CMR tuner
[Re: myduster360]
#2264528
03/06/17 09:20 PM
03/06/17 09:20 PM
Posts: 200 Colorado
Bob J
Colorado
The fact that they always transmit torque to the wheel with the MOST traction(instead of the least) is what sets that design apart. Seems it would work great for corner exit. Thanks that is what I'm looking for. Does anybody know the different lockup ratios for declaration between the units.
[Re: ahy]
#2264610
03/06/17 11:19 PM
03/06/17 11:19 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Yes, I heard the Detroit Locker is too noisy, and locks up too quick and can break things. But the 'soft' Detroit Locker is fine for autocross.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Bob J]
#2266410
03/09/17 09:16 PM
03/09/17 09:16 PM
Posts: 656 Florida
CJD AUTOMOTIVE
The Detroit Locker is going to be the best, providing you change the springs to accommodate what your doing and for the type of tires (slicks or treaded). For treaded tires, a #48 spring is what you'll want. Yes, it is a little noisy, but the abrupt lock and unlock is usually do to the unit having too high a spring rate, and once setup with the correct springs, you'll have a hard time finding a unit that can put the power down better with more predictability.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: Bob J]
#2268717
03/13/17 04:52 PM
03/13/17 04:52 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Bob. I've never had an issue or concern with the LSD as long as it was working. When the cone style was giving up during an evo school, I noticed because I was having an acceleration problem to the pivot cone. No one said anything 'til I asked because they thought cars like ours naturally spin tires. :LOL: I said "sure, two or one?" But it was hard for observers to see. There was only a single rubber mark laid down so that was the answer When I got a replacement, went to the clutch style for the same price as the cone type. However, I did not like how tight he set it, either on the street or for autocross. It changed the balance especially cold/wet looser than I liked. One of these days I'm going to set it back. OTH heck I rememeber guys showing up with Brit/euro sports cars with welded up rears 'cause LSD weren't available for them. Good ol days. You'll need to decide how tight based on power level and tires as well as if you plan any street use. My guess is your power level and tires and going to put more load on everything than mine and other 'CP light' and ESP cars. Talk to Sandbergs and other people with national level CP cars - see what they've found over the years. Some of the new locking units mentioned are really nice design. Whether they will actually perform better than your clutch unit for your build harder to say. Another person to ask would be Sam Strano.
[Re: Bob J]
#2268817
03/13/17 07:43 PM
03/13/17 07:43 PM
Posts: 200 Colorado
Bob J
Colorado
Thanks Mattax I'm going to rebuild my clutch type for one reason. Money as it seams like I'm pissing money at the moment as I still need to drop 10k or so on the car. Wheels and tires 4-5k alone. I didn't think of Sam as he is so into front wheel drive at the moment. So I'm going to start looking to see how to setup the clutch pak since the last time that I did it was for drag racing and not turning. I ordered every thing from DrDiff yesterday for the rearend plus new gears and the green bearings that I need for my brakes. Dam I would like to get this done something this year so I can some seat time so I can get it dialed in this season.
[Re: Bob J]
#2275091
03/23/17 11:47 PM
03/23/17 11:47 PM
Posts: 200 Colorado
Bob J
Colorado
I was just looking at the factory shop manual on the LSD and they give you 4 way to pack the disk but don't tell what each will do. You can guess as 2 are 5 disk setup and 2 are 3 disk setups. Anybody know? I guess I can drop it 3rd member and change it later but I's a job that I never liked to do if I don't have to.
[Re: Bob J]
#2275905
03/25/17 12:08 PM
03/25/17 12:08 PM
Mattax
Phila. Pa.
Bob - Which Company and year is the Service Manual? The '68 Plymouth only shows 3 possibilities, one for each type of carrier, each side is 5 pieces. Side Gear: Flat Plate smaller flat disk Dished Plate (beville) smaller flat disk Flat Plate, thin edit: illustration in tech archives http://www.moparts.org/Tech/Archive/axle/13.htmland some rebuilding tips in this thread. I think there was an article in one of the magazines way back about what it takes to make them tighter..
[Re: Mattax]
#2275936
03/25/17 12:54 PM
03/25/17 12:54 PM
Posts: 200 Colorado
Bob J
Colorado
Dana Power Lok Here is the manual this is from Dana Corp. Spicer Axle Division. Thanks for the info I will read through the manual that you posted. I'm not put it together for a week or so as I'm prepping all the parts for the rear and painting and trying my hand at powder coating.
[Re: Bob J]
#2282218
04/04/17 02:10 PM
04/04/17 02:10 PM
Posts: 200 Colorado
Bob J
Colorado
Thanks Mattax that was a good read. I was ready to go to the 3 disc setup till I read Mopar Mitch's post in the thread that you posted. I will have to make a choice in the next week or two so I can put it together. All the parts are now prepped and painted.I working on removing the undercoating dam I hate that job as I can only do for so long. Dam it's a [censored] to get old.
[Re: MoJoe]
#2389738
10/19/17 10:57 AM
10/19/17 10:57 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I prefer brown micro dot, but a small dose of orange sunshine is nice too Then go find a skyscraper to fly off of.
[Re: Bob J]
#2389869
10/19/17 03:53 PM
10/19/17 03:53 PM
Posts: 59 Florida
Sweet5ltr
What is the best LSD for Autocross? I have a Power lok out of my 68 that I can rebuild and how well will that work? Does anybody know the ratio on a power lok vs what else is out there? Why not give Dr. Diff a call? He builds a modern clutch type "Powr-Lok" limited-slip differential for an 8 3/4. Price is very reasonable.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
[Re: Bob J]
#2390029
10/19/17 09:33 PM
10/19/17 09:33 PM
Posts: 200 Colorado
Bob J
Colorado
I bought a kit from Dr. Diff for my power lock with a 3.55 gear set. I'm going to leave the car on jack stands for a little while long as I'm thinking of going to the Magnumforce 4 link setup. So I will need to weld on tabs for the links first if I do it. I have been side tracked on working on the GTX as the wifes 03 Dakota R/T that we bought new was totaled when she was sitting at a stop light. She was pissed but she is happy now since we bought here a 07 BMW X5 loaded with the sport package. Guess what I get to do on a used car, Yes work on it so the GTX sits a little longer.
