Holley Street Dominator intake for 318 info?
#810521
09/21/10 04:37 PM
09/21/10 04:37 PM
Posts: 172 Champaign IL
LXguy
Champaign IL
Hello:
Does anyone know the advertised rpm range for this discontinued intake?
Its a low rise single plane with small ports for 318 heads.
Thanks for any help
Steve
1971 Dodge Dart Swinger
5.9 Magnum, built 904
ET 11.70 / 113 mph
Want to swap a Magnum into your Mopar?
www.magnumswap.com
Re: Holley Street Dominator intake for 318 info?
[Re: LXguy]
#810522
09/21/10 05:37 PM
09/21/10 05:37 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Have one in the garage.Its a pretty tame intake.My kid ran it on the Charger with a small cam.It did run decent for what it was.Mainly a street intake.Rocky
Chrysler Firepower
[Re: LXguy]
#810526
09/21/10 10:46 PM
09/21/10 10:46 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Still have one from 1978.Ran it on my 318 with a 340 resto cam and a 600 Holley,headrs and 2.25 exhaust.Worked great.
[Re: 451Mopar]
#810528
09/22/10 12:44 AM
09/22/10 12:44 AM
RapidRobert
I have one that's going on a mild SB. spread bore/318 ports/divided (2 plane) plenum, didn't know it came in a single plane. I have a streetmaster single plane alum intake on a 318 right now.
[Re: RapidRobert]
#2213200
12/13/16 10:51 AM
12/13/16 10:51 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I have one that's going on a mild SB. spread bore/318 ports/divided (2 plane) plenum, didn't know it came in a single plane. I have a streetmaster single plane alum intake on a 318 right now. How did it do? I'm getting ready to try a 66-67 273 four barrel intake on some 302 heads on a 69 318-3 block with a Summit cam with 455 lift.
Moparlee
[Re: Robbins]
#2213232
12/13/16 12:07 PM
12/13/16 12:07 PM
RapidRobert
let me back up a bit as I got the two em confused. I have a Holley street dominator intake unused as of yet & it is a spreadbore low rise single plane. the BB version of it gets very good praise. the one I did use on a 318 DD in my 65 dart was a Edelbrock streetmaster square bore single plane intake & the plenum is choked down to maintain velocity for a mileage build. I dont have an idea if it was good or not but for my app with an eddy 1406 I believe it was a good choice. It was concieved I believe in the (original) gas crunch of the 70's. If I get out there today I will take some pics of both. EDIT I think the SD you have in mind would be an excellent choice for your mild app
[Re: LXguy]
#2213285
12/13/16 01:49 PM
12/13/16 01:49 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I always knew I wasn't really up to speed on all the stuff that's been available for the small blocks, and this post proves it. I had never even heard of a street dominator for a 318 before. So, I did a google search for some pics. I don't think I've ever seen one before...... Or if I have, never really noticed what it was. In looking at the pics....... It appears there was two versions of it. One an open plenum single plane without an EGR provision, the other a split plenum single plane with a channel at the rear connecting the two rear runners together, and an EGR provision. I had always thought the "318" single plane was the streetmaster intake. My knowledge base has been expanded a little today Assessing the expected usable rpm range from a couple of pics is probably pointless, but I'm going to say that a "well built" 318 with properly reworked heads and enough cam to get it there, could easily make power into the 6000rpm range using the non-EGR version of that manifold.
[Re: fast68plymouth]
#2213320
12/13/16 02:46 PM
12/13/16 02:46 PM
RapidRobert
Hey thanks for saving me the trouble of going outside to take some pics (its cold!) & the SD I have does not have that rear "channel" connecting the two rear runners.
#2213328
12/13/16 02:56 PM
12/13/16 02:56 PM
dogdays
It was the mid to late '70s., early '80s and the aftermarket was in a tizzy. Everyone wanted mileage and what they had was for power. PLUS, the EPA/CARB was threatening to outlaw ANY aftermarket stuff.
So, they went wild with experimentation and out of it came such gems as the Edelbrock Streetmaster and SP2P. Weiand I can't remember, but Holley came out with the Street Dominator. This is what we're talking about.
(severely edited from original post)Most were single plane. Most were for spreadbore carbs because that's what came on the majority of engines. Most were for EGR. The last two were to placate the EPA, IMHO.
Some worked extremely well, like the 440SD. Others worked less well. I believe the 383 Street Dominator is not nearly as good as the RB version, and the LA version was never known for its overwhelming power. For racing there were Strip Dominators.
The version of the Street Dominator that Fast 68 showed is the "Z" series and I believe it was only for the smallblock Chevy. (No, they were available for other smallblocks too). The "Z" was for Zora Arkus-Duntov and it had the plenum divided and added a connector passage between the #7 and #8 runners. It was supposedly good for another 15 hp or so, my memory isn't clear about the claims. This was in the age of 200hp Corvettes. Some of you may know that in Corvette Land, Zora Arkus-Duntov is ranked higher than the Apostle Paul and slightly lower than Jesus Christ. So using "his idea" and getting his name was a big deal for chevy folks. It was supposed to rub off on the other makes, too, I guess.
It took a few years until Edelbrock showed up with the traditional two-plane Performer series that got back to the traditional separation of dual plane for the street, single plane for top end power.
R.
[Re: LXguy]
#2213353
12/13/16 03:51 PM
12/13/16 03:51 PM
fast68plymouth
So. Burlington, Vt.
All four of the intakes I posted pics of are clearly sb mopar intakes...... No sb Chevies there.
Looks like they had both versions of the intakes for sb Chevies as well.
Easy to differentiate between the Chevy and mopar intakes..... Chevy has the hole for the dist, which is on the other side of the cam, intake bolt holes are all in a line, smaller thermostat housing is used, no water pump bypass fitting, uses a different style choke.
I also found pics of SB Ford street dominators with and without the rear runner connector channel.
[Re: LXguy]
#2213417
12/13/16 05:55 PM
12/13/16 05:55 PM
fast68plymouth
So. Burlington, Vt.
Looks like there is a third variant for the sb mopar..... Single plane, open plenum, with EGR provision.
#2213502
12/13/16 08:26 PM
12/13/16 08:26 PM
RapidRobert
Looks like there is a third variant for the sb mopar..... Single plane, open plenum, with EGR provision. thats the Holley street dominator small block intake that I have (plus the streetmaster and a torquer 2)
Last edited by RapidRobert; 12/13/16 09:53 PM. Reason: added a bit more info for clarification
#2274728
03/23/17 12:14 PM
03/23/17 12:14 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
Looks like there is a third variant for the sb mopar..... Single plane, open plenum, with EGR provision. I have this one too. Was anyone able to find some flow #'s? Trying to decide between the street dominator and an LD4B DP on a 360 blown engine. I figured the SP may be easier to jet/tune.
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
