99 Durango 46RE Trans Issues #2274017
03/21/17 11:57 PM
03/21/17 11:57 PM
Surface of the Sun, AZ
Hotwheelsjr Offline OP
I just picked up a 99 Durango 5.9 4x4. It's throwing trans codes 1765 ( Trans 12 Volt Supply Relay CTRL Circuit) and 753 (Shift Solenoid A Electrical). Anyone experience these two codes together? Is one causing the other, or do I have two separate problems? What should I be looking for? Any help would be much appreciated!
Edit: When starting out in Drive, I only have 3rd. I can manually shift into 2nd and then into Drive, but no 1st or 4th.
Re: 99 Durango 46RE Trans Issues [Re: Hotwheelsjr] #2274278
03/22/17 03:46 PM
03/22/17 03:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Check the fuse and relay in the Power Distribution Center (black box behind battery). Make sure both are good.
Re: 99 Durango 46RE Trans Issues [Re: Hotwheelsjr] #2274391
03/22/17 06:52 PM
03/22/17 06:52 PM
Thanks John. I checked the relay today and swapped it with my A/C one...no change. I'll check for a fuse...didn't realize there was one.
Also, with Google, I found a thread elsewhere addressing the exact problem I have and it claimed the PCM was at fault. It mentions grounding a pink wire on the center bundle. I checked today and see someone had already grounded the pink wire and the PCM is a Mopar reman unit -- so the previous owner has been down this road before. I'm going to guess it's something other than the relay or PCM. Here is a link to the thread...your thoughts? Discussion about the PCM and pink wire start at reply #7.
http://dodgeforum.com/forum/1st-gen-durango/187553-1999-durango-throwing-p1765-and-p0753.html
Re: 99 Durango 46RE Trans Issues [Re: Hotwheelsjr] #2274670
03/23/17 09:57 AM
03/23/17 09:57 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
48re is nearly identical, correct?
Starting out in 3rd is usually the fault of the shift solenoid and/or transducer in the valve body. Buying the upgraded borg warner piece and replacing the transducer is around $100 in parts.
I had this symptom in my cummins and these 2 parts fixed it
**Photobucket sucks**
Re: 99 Durango 46RE Trans Issues [Re: Hotwheelsjr] #2274794
03/23/17 02:05 PM
03/23/17 02:05 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Ok I took a look in dealer connect. The
trans control relay sends 12v to the various slonoids. If it's only missing voltage to the 3/4 shift solenoid 12v supply is not the issue. The 3/4 solenoid is controlled by the PCM grounding circuit T60 (brown wire) at connector C2 cavity 21. Either the 3/4 solenoid, open in circuit T60 or a faulty PCM. To test disconnect PCM connector C2 test lamp connected to ground and pin 21. Touch a wire connected to ground to cavity 30 (pink wire). If the solenoid and circuit are good the test lamp wil illuminate.
Doug
Re: 99 Durango 46RE Trans Issues [Re: dvw] #2274872
03/23/17 04:32 PM
03/23/17 04:32 PM
Doug
Thanks -- I'll go try that. I noticed someone has already grounded the pink wire, I assume to bypass the relay? In my post above there is a link to a thread on DodgeForum advising grounding the pink wire is a "temp fix". I have to assume leaving this pink wire grounded will eventually fry something...like the PCM or the 3/4 solenoid.
When you say "cavity", I am assuming that means the female receptacle on the PCM? Connector C2 is going to be the middle connector?
Thanks again!
Mike
Re: 99 Durango 46RE Trans Issues [Re: Hotwheelsjr] #2275088
03/23/17 11:37 PM
03/23/17 11:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Yes cavity is terminal location in the connector. Grounding the pink circuit mention takes the control of the relay away from the PCM. All the relay does is feed power to the various solenoids. They are commanded on by the PCM grounding the individual circuits controlling each solenoid.
Doug
Re: 99 Durango 46RE Trans Issues [Re: dvw] #2275166
03/24/17 01:47 AM
03/24/17 01:47 AM
Doug
Thanks Doug. The rango is at my buddy's shop...I'll be going there tomorrow to check this out.
-- Mike
Re: 99 Durango 46RE Trans Issues [Re: Hotwheelsjr] #2278112
03/29/17 12:56 AM
03/29/17 12:56 AM
FIXED! Replaced the PCM and output speed sensor. Codes are clear and it now shifts the way it's supposed to. Thanks all!
-- Mike
Re: 99 Durango 46RE Trans Issues [Re: dvw] #2310090
05/24/17 12:00 AM
05/24/17 12:00 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Doug
I swapped in a Durango drivetrain into My wrangler and I have the same codes. if I am understanding this test, my light is not lighting up. Are there any other tests I can perform?
