Correct Fuel Filter on '68 Satellite
#2272918
03/20/17 12:43 PM
03/20/17 12:43 PM
Posts: 412 Jackson, Mississippi
CornDogsCharger
I have an all original unrestored '68 Satellite with 76k original miles. The original owner was a stickler for keeping the car mechanically tuned, so various parts were replaced over the years. I am slowly trying to put the car back how it originally was. My question is... on a '68 Satellite with a 273ci what is the correct style fuel filter that would have come on the car? I see a plastic date coded one and the metal date faded one as well. Thanks! Justin
1966 Dodge Charger 1968 Plymouth Satellite (Un-Restored "Survivor") 1969 Dodge Charger (W.B. General Lee) 1969 Dodge Charger (Future DMCL Clone) 1969 Dodge Super Bee, 383 4spd
Re: Correct Fuel Filter on '68 Satellite
[Re: CornDogsCharger]
#2272938
03/20/17 01:09 PM
03/20/17 01:09 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Please someone more knowledgeable chime in please! I don't think our old Mopars came from the factory with these in-line fuel filters, but most people add them. I "think" you might have just had a brass filter inside the carburetor inlet.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2272965
03/20/17 01:41 PM
03/20/17 01:41 PM
CornDogsCharger
Please someone more knowledgeable chime in please! I don't think our old Mopars came from the factory with these in-line fuel filters, but most people add them. I "think" you might have just had a brass filter inside the carburetor inlet. I wondered that too. I noticed the fuel lines are offered as a one-piece or a two-piece, where an online filter would be used. I just want to do what was correct. Thanks! Justin
#2273102
03/20/17 04:51 PM
03/20/17 04:51 PM
CornDogsCharger
I may have just answered my own question. I have a '69 parts manual at work and just checked it. It calls for the metal filter part #2525254. I have a '68 manual at home and will check it this evening.
Justin
#2273626
03/21/17 01:03 PM
03/21/17 01:03 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
If it's metal in 69 I would think 68 would also be metal , are you building for 100% OE judging ? OH FYI , that part number you point out is from roughly 1964 or 1965
#2273831
03/21/17 06:19 PM
03/21/17 06:19 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
OK, then the metal can fuel filters are "stock" and those pictures provided by Mattax look familiar from junkyards.... explains the two-piece fuel line thing too.
#2274330
03/22/17 04:49 PM
03/22/17 04:49 PM
CornDogsCharger
I checked my '68 parts manual and it gave the same 2525254 part number.
JohnRR, I am not really going for 100% OE judging, but the car is so very original with the exception of a few mechanical things here and there, I've already had people want to look at it for reference... I just figured everything should be "correct" as possible. I just want to replace the parts that have already been replaced it what it originally had.
Mattax, I have seen the red spring clips used as well. I planned on running them as well. Good point. I think the parts vendors like you use the term "OEM Style" for a part that is basically a "service part"... and it somewhat looks the same but would be made by Fram or Wix, or along those lines.
Thanks! Justin
[Re: JohnRR]
#2274481
03/22/17 09:48 PM
03/22/17 09:48 PM
CornDogsCharger
Is there a part number on either of those in that catalog pages that you show ? The plastic one and the metal one both have the part number 2525254 stamped on them. After looking into it a little further, the plastic was used up to 1967 model cars and in 1968 was only on Super Stock cars... otherwise the metal 2525254 filter should be used on 1968-up cars. Justin "CornDOg"
#2275111
03/24/17 12:21 AM
03/24/17 12:21 AM
Posts: 307 Georgia
69bfan
Georgia
Justin, If you decide to order the filter, I believe that you are aware that there is a "assembly" line style and the "over the counter" style. The same filter, just a difference in which the date coding is printed in a different position.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
