'70 440+6 Roadrunner Oil Dipstick
#2273672
03/21/17 02:11 PM
03/21/17 02:11 PM
Posts: 955 Chicago
PurpleBeeper
Chicago
I've decided to get a new oil dipstick and actually use the motor mount bolt "loop" so I don't pull it out of the block. I've added Hedman 1-5/8" headers & I have the #1 cylinder's primary pipe going right over the top of the #3 cylinder's spark plug before turning down after exhaust port #5 (runs left-right, sorry no picture). I've been using a slightly modified "el cheapo" chrome dipstick & I think I bent it to clear Hooker headers I had on there before, if that matters. [IMG] I've got an aftermarket oil pan on the car (Milodon "six pack" style). Even though I marked the dipstick after I put in fresh oil (7 qts. with filter), I'm still not 100% sure my oil level is correct. My thinking is that "whatever" pan you put on a 440, the oil level distance below the block's oil pan rail should be the same.... deeper pan = more oil, but the "full mark" should still be correct regardless of the pan you're using. Does that sound right? http://thumbs.ebaystatic.com/images/g/XxwAAOSw6DtYUARG/s-l225.jpg Here're my other questions: 1. Would another "el cheapo" dipstick like shown above read my oil level correctly? OR, will I have to calibrate it myself when I do an oil change? 2. Would the factory OEM dipstick clear my headers? 3. If I had to bend a factory OEM dipstick to clear my headers, would that affect the "full" mark? 4. What is the correct Chrysler part number for a '70 440+6 Roadrunner? 3698500? I'm sorry this is sort of rambling. I'm wondering if I'm worried over nothing and/or over-thinking this situation. I just want to be sure my oil level is at the correct height. I have an oil leak and I'm wondering if I'm over-filling the engine. THANKS!
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Re: '70 440+6 Roadrunner Oil Dipstick
[Re: mikemee1331]
#2273814
03/21/17 06:01 PM
03/21/17 06:01 PM
Posts: 955 Chicago
PurpleBeeper
Chicago
on my 440 with those headers i placed the dipstick (looks like the one you showed) between the the header pipe and the block. fits real nice. as far as the pan depth, the stick isn't necessarily reading how much is actually in it but rather how full it is.
(yes, you're over-stressing it) That's sort of what I'm thinking.... how full (how close to bottom of block's pan rail) the pan is. That means that if you had a factory OEM dipstick & tube and you put a Moroso 9qt. deep sump pan on the motor, the dipstick would still read correct (just the pan holds more oil). Can anyone else confirm this? The problem that worries me is that the factory OEM dipstick is long gone....not sure I ever had it. All I have is this bent up aftermarket chrome tube & stick calibrated to who knows what. PLUS, I'm not 100% sure what the volume of my Milodon oil pan is.... supposed to be a "six pack" pan. Any other comments/tips are appreciated. Anyone know the factory part numbers?
[Re: PurpleBeeper]
#2274027
03/22/17 12:13 AM
03/22/17 12:13 AM
Posts: 3,136 Palm Coast, FL (near Daytona B...
Blown_Hemi
Purple beeper you are correct. Pan depth does not matter, just holds more oil. It is the oil level below the pan rail. I would find a tube that fits and dipstick. Fill engine with oil, depending on pan size. Then mark dipstick. That is how I did my 440 truck with an 8 quart pan. My dipstick mounts into pan.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
[Re: Blown_Hemi]
#2274033
03/22/17 12:26 AM
03/22/17 12:26 AM
RapidRobert
On a problem child what I do is fill the pan with the # of qts it holds, (4 for instance) on a level surface & remark the stick at that point OR if using a longer OE or aftermarket stick, shorten the dipstick tube till the oil level is right at the OE Full mark on the stick. So that with the filter filled and the oil passages primed, there is exactly 4 qts in the sump when you check it in the morning before starting the engine.
[Re: Morty426]
#2274844
03/23/17 03:28 PM
03/23/17 03:28 PM
Posts: 955 Chicago
PurpleBeeper
Chicago
3462415 is the tube part number and I think you can still buy it Thanks Morty.... do you know the number for the dipstick too and/or the tube + stick?
[Re: PurpleBeeper]
#2275106
03/24/17 12:07 AM
03/24/17 12:07 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
3462415 is the tube part number and I think you can still buy it Thanks Morty.... do you know the number for the dipstick too and/or the tube + stick? Yes the dipstick is 3512078 but I have not confirmed how correct that part is. The tube I know is correct.
[Re: PurpleBeeper]
#2277245
03/27/17 04:44 PM
03/27/17 04:44 PM
Posts: 955 Chicago
PurpleBeeper
Chicago
I found this over at Roseville's website. I'm not concerned about "correct". I'm making an ASSUMPTION here that the #2078 (70-71 B/E body big block) is bent differently than the #9246 (66-69) or #2840 (64-65 B-body or 65-68 C-body) due to differences in their exhaust manifold shapes or something like that. Is that right? http://www.rosevillemoparts.com/images/p...orrect-9617.jpgThey all bolt to a motor mount bolt, right? I'm sure I'm over thinking this, but could I use ANY of these? I've got a '73 block in a '70 car with headers. Will they all be accurate? Will one clear headers better than the others? Any ideas/tips are appreciated.
