Mounting electronics inside your race car...pics? #2273764
03/21/17 03:40 PM
03/21/17 03:40 PM
an8sec70cuda Offline OP
I want to make some sort of panel to mount in the passenger's floorboard, or semi-underneath the dash, to mount my electronics to. It's gotten to the point where I have a few things mounted under the dash now and I want to clean it up while making it more accessible.
The ignition box, timing retard box, nitrous progressive, 2 step, etc. takes up some room.
I'd like to see some pics of how yall have mounted your electronics inside the car. up
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'70 'cuda, 575" Hemi, 727, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'73 Chrysler New Yorker, 440, 727, 8.75....................FOR SALE
'06 GMC 2500HD LBZ Duramax
'17 Ram 1500 5.7 Hemi
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2273766
03/21/17 03:47 PM
03/21/17 03:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you still have a glove box and are you using it
wave
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2273767
03/21/17 03:47 PM
03/21/17 03:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have my EFI computer under the seat and my relays and terminal blocks under the dash. Someday when I redo this I will try to fit it all under the passenger seat. It is way easier to pull the seat out than it is to cram my 6'3 240lb self under the dash with the cage and down bar.
68 Barracuda Formula S 340
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2273771
03/21/17 03:54 PM
03/21/17 03:54 PM
Mr P...I have the ignition box and 2 step mounted in the glove box area. The timing controller is underneath the glove box mounted on the bottom of the dash frame. Currently just using a digiset for the nitrous mounted on the bottom edge of the firewall.
I'd like to get it all in one area and easier to get to.
Bad340...I like that idea! I'm 6'5" 330 lbs so I know what you mean!
My car has all the factory interior still in place, except for the heater box assembly which has been removed. I thought about the kick panel area, but the rollcage down bars are kinda in the way and the kick panel is to small anyway I think.
CHIP
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2273772
03/21/17 03:54 PM
03/21/17 03:54 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Paging member Justadart! Rod has made some nice set ups.
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2273774
03/21/17 04:05 PM
03/21/17 04:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Right now I run a MSD 7AL for ignition but I will
be pulling that out and mounting the Holley HP
controller where that is.. that will open up space
for me... I was gonna put the controller under the
pas seat but I didnt want that wad of wires running
along the edge of the floor.. digisets are small so
that doesnt take up much space
wave
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2273795
03/21/17 04:42 PM
03/21/17 04:42 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I'll see if I can dig up some pics.
In my dart I made an aluminum sheet that resided where the heater box use to, mounted all my electronics there with some terminal blocks, came out OK. When I re-do it, the passenger side of the dash will be removable...I am done monkeying under the dash...haha
The Plymouth still has the heater box, so I made a double layer lexan panel that mounts to the bottom of the heater box that houses all my aux wiring, relay bank, N2O controller, and serves as a terminal block for all the EFI junk.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Mounting electronics inside your race car...pics? [Re: OUTLAWD] #2273797
03/21/17 04:47 PM
03/21/17 04:47 PM
outlawd...I'd really like to see pics of those!
CHIP
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2273830
03/21/17 05:19 PM
03/21/17 05:19 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I can't get the pics on my phone to load on here.
I put a piano hinge and put it on one side and 2 dzus on the other so it flips up under the dash .
PM me your phone number and i'll text them to you .
Re: Mounting electronics inside your race car...pics? [Re: a493demon] #2273836
03/21/17 05:31 PM
03/21/17 05:31 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Took me a little while to figure it out but you can download a free photo resizer, it will resize the photo and automatically put it in a folder in your photo gallery. Then you can post it here from your phone.
Re: Mounting electronics inside your race car...pics? [Re: ProSport] #2273875
03/21/17 06:57 PM
03/21/17 06:57 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have been pondering this very topic on my red Charger re-build project. At one point I thought of tacking a hinge to the firewall that would allow the mounting surface to swing down for access. There are typically a lot of fuses on these boards and access could be had from the open glove box with some careful layout and ingenuity. It's a tough balance, you don't want the board exposed yes you still need easy access to it.
Re: Mounting electronics inside your race car...pics? [Re: Jeremiah] #2273902
03/21/17 07:51 PM
03/21/17 07:51 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I have my MSD and fuses mounted on a swing down plate on my GTX, and am doing the same on the Road Runner. It is held up with a magnet.
69 GTX 68 Road Runner
Re: Mounting electronics inside your race car...pics? [Re: JERICOGTX] #2273906
03/21/17 07:56 PM
03/21/17 07:56 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Not the best picture, but here is the GTX.
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2273927
03/21/17 08:25 PM
03/21/17 08:25 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
in the glove box area here.
Doug
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2273931
03/21/17 08:29 PM
03/21/17 08:29 PM
Parts unknown
590 Challenger Offline
Parts unknown
I mounted mine on the passenger floor. Aluminum frame, Plexiglas panel. I lined up relays and made my own bus bar for each relay (lights, transbrake, shifter, ignition, Fan, Line Lock. Anything new I want powered from one of those relays , there is a screw waiting to tap in. No future splice, everything marked ready to go
If I had to do again I would I would have put in the triangle of the roll cage in the door way
Re: Mounting electronics inside your race car...pics? [Re: 590 Challenger] #2273945
03/21/17 08:59 PM
03/21/17 08:59 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Under the dash easy access..
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2273964
03/21/17 09:35 PM
03/21/17 09:35 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Hi Chip, here's what I did.
I made a little panel out of carbon fiber for the box and some relays, digiset on the firewall.
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2274149
03/22/17 10:06 AM
03/22/17 10:06 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Sorry for the quality...cell phone pic during mock-up of the Plymouth wiring...
Wiring is not my thing unfortunately, and I had to fit this on the underside of the heater box, so this hangs upside down (in hindsight, a hinge is a good idea). Its just tinted 1/8" lexan from McMaster, and I used the same to make a cover so the passenger doesn't kick any live wires.
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2274185
03/22/17 11:33 AM
03/22/17 11:33 AM
Renton Washington
Triple Threat Offline
Renton Washington
Chip,
Take a peak here, you'll spend hours reading through it, some truly impressive work;
http://www.yellowbullet.com/forum/showthread.php?t=431340
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Mounting electronics inside your race car...pics? [Re: an8sec70cuda] #2274186
03/22/17 11:37 AM
03/22/17 11:37 AM
Sterling Heights, MI
John_T_Brown Offline
Here are pics of the electrical system as it is today. The MSD Grid is mounted in triangle plate on the passenger side of the roll cage. The Racepak Smartwire is mounted just behind the passenger door along with Racepak V300SD to prevent any electrical interference with the Grid. The electrical panel for the Grid shifter and associated wiring connections are mounted in the glovebox opening. Hope it give you some ideas for your build.
If it ain't broke fix it anyway!
