Ramcharger – Air Box Rivets #2273559
03/21/17 11:00 AM
03/21/17 11:00 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I have a Ramcharger air box assembly from a 1970 Coronet R/T. I would like to replace the rivets (flower/mushroom) that hold the two halves of the air box together. Unfortunately, I do not have a pic at the moment of the underside of the air box assembly that shows the rivets flower/mushroom flare. Anyone know who sells the rivets?
Re: Ramcharger – Air Box Rivets [Re: vinnyd76] #2273617
03/21/17 12:53 PM
03/21/17 12:53 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Try Air Grabber Restorations in Cincinnati Ohio, 513 528 7922
Re: Ramcharger – Air Box Rivets [Re: vinnyd76] #2273631
03/21/17 01:09 PM
03/21/17 01:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Do they look like these?
Re: Ramcharger – Air Box Rivets [Re: Challenger 1] #2273655
03/21/17 01:37 PM
03/21/17 01:37 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Snowmobile shops used to have tons of those rivets in stock if you can't find an easier source.
Sheldon
Sheldon
Re: Ramcharger – Air Box Rivets [Re: vinnyd76] #2273868
03/21/17 07:36 PM
03/21/17 07:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Like early Fox-body Mustang bumper cover rivets.
Re: Ramcharger – Air Box Rivets [Re: vinnyd76] #2273925
03/21/17 09:25 PM
03/21/17 09:25 PM
cbusters Offline
cbusters  Offline
I am doing the same thing to an Air Grabber. After talking to suppliers it appears that the rivet isn't special, it is the die that is used to flair it. It apparently has sharp edges that cut the tube end of the rivet as they roll over. Working on getting the dies for my "squeezer" as we speak.
Re: Ramcharger – Air Box Rivets [Re: DAYCLONA] #2274018
03/21/17 11:58 PM
03/21/17 11:58 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you for the info... Unfortunately, they will not sell the hardware alone. They want to restore the air box.
Re: Ramcharger – Air Box Rivets [Re: vinnyd76] #2274019
03/22/17 12:01 AM
03/22/17 12:01 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Attached is a pic (not so clear) of the opposite side of the rivet used to retain the two halves of the air box. Flower style rivet.
Re: Ramcharger – Air Box Rivets [Re: vinnyd76] #2304238
05/14/17 11:25 AM
05/14/17 11:25 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Update on the Air Grabber restoration.
A friend and local Moparts member, Mike Modarski (user name: 1970_EK2AAR), successfully located the correct rivets (same supplier that the company in Cincinnati purchases hardware from). Mike drilled out all the old rivets, cleaned the inside of the assembly and completely restored the air grabber. The assembly turned out really nice! This was Mike's first air grabber restoration. Mike is very detailed with his work, so I was confident the project would turn out well. The completed air grabber assembly was shown locally to a well known Mopar restorer/enthusiast where is was perceived as NOS.
When I picked up the air grabber from Mike, he had the entire assembly bolted to sturdy cardboard and wrapped in plastic for easy transport.
Attached are some photos for your review.
Please contact Mike, if you are interested in having your air grabber restored. I have additional photos of the restoration, if you would like to learn more.
Re: Ramcharger – Air Box Rivets [Re: vinnyd76] #2304483
05/14/17 08:07 PM
05/14/17 08:07 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
A photo showing the Air Grabber installed in the 70 Coronet R/T.
Re: Ramcharger – Air Box Rivets [Re: vinnyd76] #2304763
05/15/17 10:35 AM
05/15/17 10:35 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Looks great!!
68 Charger
70 Cuda
Re: Ramcharger – Air Box Rivets [Re: vinnyd76] #2304931
05/15/17 03:37 PM
05/15/17 03:37 PM
Chicago
PurpleBeeper Offline
Chicago
Nice freaking work!
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Ramcharger – Air Box Rivets [Re: PurpleBeeper] #2304944
05/15/17 03:57 PM
05/15/17 03:57 PM
Manitoba, Canada
70NetRT Offline
70NetRT  Offline
Manitoba, Canada
Nice Work.
Any chance of sharing the name of the rivet supplier? Some of us are financially challenged when it comes to our projects and would prefer to do the work ourselves.
Re: Ramcharger – Air Box Rivets [Re: vinnyd76] #2304974
05/15/17 05:05 PM
05/15/17 05:05 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The Coronet is looking GOOD!
