Gonna build an engine #2261999
03/02/17 02:05 AM
03/02/17 02:05 AM
Santo domingo, dominican repub...
John2869 Offline OP
John2869  Offline OP
Hi guys, as the subject says I'm planning on building an engine. My car's a 74 challenger, used to be my daily driver, kept it running myself mostly but things got a little tough over here (i live in Dominican Republic, ordering parts got real expensive) so i had to get a modern car.
Now things are looking up, sent the car to get some rust removed, fresh coat of paint and brand new interior and since it's not my everyday car anymore im gonna do an engine swap. Been reading a lot, i know my way around a car but it's my first time building an engine, found a lot of info and i have a pretty good idea of all the upgrades i'll have to make...only thing i dont know is if a gen 2 HEMI will fit.
Any imput would be greatly appreciated, i'll be posting the project in the project section tomorrow with pics.
Re: Gonna build an engine [Re: John2869] #2262012
03/02/17 02:16 AM
03/02/17 02:16 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
A Hemi fit in a 70, and 71 E body, so it would fit in a 74
Re: Gonna build an engine [Re: 71birdJ68] #2262016
03/02/17 02:22 AM
03/02/17 02:22 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Yup, those early years came with a Hemi. Depends what engine came in that car as to what is needed to swap in a Hemi - big block, small block, or slant six.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Gonna build an engine [Re: John2869] #2262085
03/02/17 10:25 AM
03/02/17 10:25 AM
John2869 Offline OP
John2869  Offline OP
Thought so, just making sure before ordering parts. Thanks for your help and i'll kepp you posted.
Re: Gonna build an engine [Re: John2869] #2262093
03/02/17 10:48 AM
03/02/17 10:48 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Do a lot more research before ordering. If your car is a 318, you can't just drop in a 426. You will need to swap the front suspension, k member, transmission, etc. if parts are hard to get for you, then I would stick to the same engine family. If it's a 318, build a 360 stroked to 408. It will be a direct swap. Were there even any big block e-bodies in 74? If yours is a big block, then you have a lot of the parts needed for a hemi but be ready for sticker shock. A 400 can make a really stout stroker too for 1/4 the price
**Photobucket sucks**
Re: Gonna build an engine [Re: John2869] #2262184
03/02/17 02:16 PM
03/02/17 02:16 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If ordering regular parts gets expensive, you'll fall over when you see hemi prices! laugh2 Seriously, best of luck, your Hemi Challenger will be awesome!
Some things to consider, if your car is a factory V8 car, you'll probably need the conversion motor mounts from engine-swaps.com if yours is a slant 6 car, I think you need a V8 k-frame to even get started.
Also, if your car is a factory slant 6 or small block car you will need a different transmission and a new rear differential will be on your to-do list as well.
Re: Gonna build an engine [Re: DaytonaTurbo] #2262201
03/02/17 03:02 PM
03/02/17 03:02 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
OP's 74 Challenger came with one of two engines. 318 or 360. Slants and big blocks weren't offered.
Re: Gonna build an engine [Re: 318 Stroker] #2262203
03/02/17 03:09 PM
03/02/17 03:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
This is correct.
Re: Gonna build an engine [Re: John2869] #2262561
03/03/17 11:04 AM
03/03/17 11:04 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
That's what I thought but couldn't remember for sure.
Re: Gonna build an engine [Re: John2869] #2262599
03/03/17 12:38 PM
03/03/17 12:38 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Building a Hemi can be one of the most frustrating and rewarding tasks you can do in the Mopar world. I've built one. Will never do another. There are many people here on the board that can help. Some hang out over in the race forum more, so post engine questions there.
Some things to consider: Cost. A hemi will be on the upper end of the spectrum. Once the part description has Hemi in it, the costs is 2-3x. You can use original parts, which you will be competing with restoration guys for which drive costs up, or use aftermarket, which don't always fit and may need some attention to work right. So you may get a bit lower cost, but added frustration. In either case, some parts are pretty scarce and will put a substantial dent in your bank account. Second: overall drive train. If your car had an 8 cylinder, there are conversion mounts that allow Hemi to bolt in. TTi headers will clear everything. They cost, but fit. Clutch/trans will be an issue if you are building big power (and why not if you are already building a Hemi). You will need a McLeod street twin and preferably a Hemi 4spd (18 spline). A 23 spline may hold up, they are pretty robust to around 450 to 500 ft-lbf torque from what I have read. Maybe that is optimistic though. Rear end will be an issue too if you don't have at least a decently built 8-3/4. A more stock build Hemi would probably work fine in front of a 23 spline trans and 8-3/4" rear with street tires. The tires will be the "fuse" in the system that will break away first.
If you can handle that, then I say go for it. Otherwise, a decent wedge with a stroker can build almost as much power for less cost. You will still have drive line concerns though, as a decent 440 with a 499 stroker kit and aftermarket heads can get 600 hp. You will still need a v-8 k-frame too.
Good luck.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Gonna build an engine [Re: John2869] #2262730
03/03/17 04:31 PM
03/03/17 04:31 PM
chicago ,Il usa
hato Offline
hato  Offline
chicago ,Il usa
welcome to the board a gen 2 hemi is pricey like most have said if your dead set on having a hemi may i suggest going gen3 hemi? there is plenty of motors out there and the swap can be done for half of a gen2 the nice thing about the gen 3 is you can daily drive if you wish and not worry about performance vs mpg
Re: Gonna build an engine [Re: John2869] #2263082
03/04/17 03:00 AM
03/04/17 03:00 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
As stated above ,Hemi =$$$$$$ lots of them. I'm putting one togeather ,been about 4 years of buying expensive parts. After spending about $10,000 and being nowhere close I thought WHAT THE HELL WAS I THINKING>
Re: Gonna build an engine [Re: John2869] #2263095
03/04/17 03:44 AM
03/04/17 03:44 AM
Cab_Burge Online work
Cab_Burge  Online Work
I'm building a 426 Street Hemiroid motor for a local customer for his 1970 Challenger, the motor is being built with mostly new parts, new World 4.490 rough bore block, used older KB top fuel 4.500 stroke crank, a set of lightly used Manley steel I beam SS rods, new custom made Diamond pistons, new Stage V heads, used Stage V cast aluminum valve covers that will be polished, all new Stage V rocker gear, new custom made Manton pushrods, new polished 2x4 inline Stage V intake manifold set up for EFI with dual 4150 dry throttle bodies, solid roller cam and lifters, seven quart Milidon road racing oil pan and probably a Milidon external oiling system.
Any hemi motor, Gen 1, Gen 2 or the new Gen 3 will not be cheap or easy to build to get good results, hence my Hemiriod name for them pain in the rear motors shruggy
I've been racing and building the Gen 1 Chrysler Firepower Hemi and Gen 2 Mopar 426 street hemi motors for a long time,(started in 1965 on my first 1955 Chrysler 331 motor) no experience yet on the new Gen 3 motors, yet shruggy
EDITED : Buying any parts for the 426 hemi will be expensive and their are currently no new cast iron blocks being made so plan on buying a new aluminum block or wait for a new cast iron block to be made or look on the internet trying to buy all the used or new parts needed to build your motor shruggy
Hemi motors are impressive and they can be made to make a lot of power, but not cheaply or easily work
Think long and hard before choosing, just like marriage work
Good luck regardless on what you choose to build up down
Re: Gonna build an engine [Re: John2869] #2263244
03/04/17 02:27 PM
03/04/17 02:27 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Cab
Let me know when you're ready for the EFI. If you have my book, you saw one of my early dual throttle body EFI 572 HEMIs. Lots of changes since then.
Rich
Re: Gonna build an engine [Re: John2869] #2263281
03/04/17 03:30 PM
03/04/17 03:30 PM
rowin4 Offline
rowin4  Offline
Rich, I have your book . How can we find out the latest changes in EFI
Re: Gonna build an engine [Re: rowin4] #2263543
03/05/17 03:04 AM
03/05/17 03:04 AM
Yes, consider other engines (highly recommended).
Re: Gonna build an engine [Re: John2869] #2263609
03/05/17 12:41 PM
03/05/17 12:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A well thought out 360 or 318 stroker will put the car in the 12's easy and be very streetable. Far less expensive. My Challenger runs stock ported heads, dual plane intake, headers, 224@.050 cam. With a 3.55 gear its been 12.70. Also important it runs on 86 octane.
Doug
Re: Gonna build an engine [Re: Mopar_Rich] #2273596
03/21/17 12:06 PM
03/21/17 12:06 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Originally Posted By Mopar_Rich
Cab
Rich
I have your book - good stuff!
So, is there an updated or new book in the works?
Maybe a book on some basic/fundamental EFI tuning?
Thanks!
Re: Gonna build an engine [Re: John2869] #2273621
03/21/17 12:58 PM
03/21/17 12:58 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I considered a book on EFI, but I decided that the rapid changes in electronics and software development would mean the book would have a short pertinent life. The basics would hold because the physics of a 4-stroke engine don't change, but a reader would probably want some specifics about products that are currently in the market and how they are different. That could be a series for a magazine.
But I am considering something online that would be available through my web site. There I could cover the EFI basics that are product independent and then let the reader take whatever path he wants depending on the product that's of interest.
Then I could follow up with an online training course for the specific products I support. I would charge a fee for each course. I have written interactive correspondence courses before and they can work very well if the reader can download work books, quizzes and can track their progress.
Or maybe I'll just go fishing!
Re: Gonna build an engine [Re: Mopar_Rich] #2273637
03/21/17 01:18 PM
03/21/17 01:18 PM
Ding ding ding I (do) believe we have a winna.
