csr trans sheild #227319
02/16/09 09:29 PM
02/16/09 09:29 PM
Port Mcneill,B.C.Canada
I
Islandcuda Offline OP
I
Hi guys, does the transmission have to come out to install csr trans sheild> or just drop it from the rear a bit, thanks Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: csr trans sheild [Re: Islandcuda] #227320
02/16/09 09:31 PM
02/16/09 09:31 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
come out .. and then some
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: csr trans sheild [Re: bigdad] #227321
02/16/09 10:18 PM
02/16/09 10:18 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I had to cut the cast in tab's off mine and also the boss for the kickdown linkage, I even have a removable trans tunnel and cussed it , I pity the guy's with factory tranny tunnels.
Re: csr trans sheild [Re: dartman366] #227322
02/16/09 10:52 PM
02/16/09 10:52 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if its goin in a stock tunnel you will have to also peen over the pinch weld between the firewall and tunnel. i dont know you or your car, but if it aint like some kinda original collecter car do yourself a big favor and drill some holes thrugh the fire wall to put the tranny bolts in,its a tight squeeze with sheild because the bolts have to be longer.
Re: csr trans sheild [Re: bonefish] #227323
02/16/09 10:55 PM
02/16/09 10:55 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I never did get one to fit my factory tunnel. I ended up getting a blanket.
Re: csr trans sheild [Re: WILD BILL] #227324
02/16/09 11:09 PM
02/16/09 11:09 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We had to do some serious to the stock tunnel to get it to fit in the Duster. Also had to cut the ears etc.. off the tranny to get it in.
Re: csr trans sheild [Re: cl440] #227325
02/16/09 11:22 PM
02/16/09 11:22 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
I think I can hear Tim screaming from from my house.
Re: csr trans sheild [Re: cl440] #227326
02/16/09 11:25 PM
02/16/09 11:25 PM
Mission BC
10sec440 Online content
10sec440  Online Content
Mission BC
Hi Tim! I fit mine in the stock tunnel but it was a PITA. Peen the seam, cutting holes for the bellhousing bolts is almost mandatory, and cut the tabs off your trans. Another important thing is make sure nothing is touching it. If it gets any heavy gouges, cuts or scrapes it won't pass recert and will only be good for 5 years.
Re: csr trans sheild [Re: 10sec440] #227327
02/17/09 12:12 AM
02/17/09 12:12 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Another vote for Major pain in the ...
I had to fold the pinch seam over also, and cut a rather large hole in the floor of my duster to make it clear.
I'm not sure why you guys all say to drill holes in the firewall though. I didn't think it was really that bad to install the bolts. But if you had a mid-plate in the car, and couldn't angle the trans/motor down, I could see why you'd need to...
Re: csr trans sheild [Re: dizuster] #227328
02/17/09 12:46 AM
02/17/09 12:46 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
make sure you tighten that belt as hard as you can cos it's a beach to get it tight once the trannys back in place. i bought a 24" long 3/8 socket extention to do mine. with practice it's not so hard to do but its a 2 man job.
Re: csr trans sheild [Re: rebel] #227329
02/17/09 02:03 AM
02/17/09 02:03 AM
I
I
Interesting stuff guys,lol, sounds not much better than the tci sheild I,m trying to install now.I originally bought a tcs sheild and I cut the top of my tunnel off and added a tunnel from a chevy truck to get it to fit. My supplier told me tcs didn,t make them anymore so I bought the tci one and it hit,s the tunnel, bolt holes won,t line up etc. I finally got it all together and trans in the car and forgot to put the shifter linkage on with the spacers after pulling the sheild in place with ratchet straps, soooooooo I undid the one drivers side to get the linkage in place and no way in hell I can pull it all back together. Sounds like the trans is coming out again wether I like it or not. I will except this I guess,lol and try to put it together again with the shifter linkage in place and see how it goes, Tim
Re: csr trans sheild [Re: Islandcuda] #227330
02/17/09 04:39 AM
02/17/09 04:39 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
fit perfectly fine for me, never touched the pinch weld or anything. guess i have an oddball. 68 coronet, hemi with converted k member, stock mounts. it is pretty tight in there though. you can gain about a 1/2 inch by moving the belt around since one of the lugs hits the trans housing
oh i did cut the shield though since i was definately not going to cut the tabs off the trans. they say that voids the cert? well my car don't qualify for any of there certs anyways so im cool with that.
Re: csr trans sheild [Re: prochargedhemi] #227331
02/17/09 12:48 PM
02/17/09 12:48 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
one more thing to check,i had two csr sheilds that the bolt holes didnt line up.you have to actually strap it down and make sure the bolts go STRAIGHT thru when the shield is tight,its a real pain when you get it all put together and every thing is perfect except one stinkin bolt hole is off.
Re: csr trans sheild [Re: bonefish] #227332
02/17/09 01:56 PM
02/17/09 01:56 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
I've have used a 904 727 csr shields the older ones had allen bolts so i made a short tool to usewith a long extention then the newer one had 6 pts bolts so i use 6pt socket with a 3/8 ratchet wrench works pretty good .All my trans i cut the ears off dont need them ..I still like them over a blanket .TCI you will cuss it till you throw it away will not fit a tunnel pry to get if not all most bolts in PIA
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: csr trans sheild [Re: 10 o to go] #227333
02/17/09 02:02 PM
02/17/09 02:02 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Mine fit fine after a little
Re: csr trans sheild [Re: bigdad] #227334
02/17/09 02:06 PM
02/17/09 02:06 PM
boscosis Offline
super street
boscosis  Offline
super street
I know that we've all seen the questionable pics of the blown-alcohol car. Has anyone here exploded a tranny into one of these shields and seen what happened? In my own case we went with the largest blanket we could find b/c we didn't feel that a carbon fiber shield offered the most protection.
Re: csr trans sheild [Re: boscosis] #227335
02/17/09 03:54 PM
02/17/09 03:54 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
A blanket is fine as long as you only plan upon running 10 seconds or slower. You still need the bell housing covered to run faster making the CSR shield the best option out there? And I have seen one of these shields in a 9 second car put to the test. The driver was not injured but the shield was toast. Did it do its job?????
Re: csr trans sheild [Re: atoetly] #227336
02/17/09 08:32 PM
02/17/09 08:32 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
This is the one thing that makes me think about putting a glide in my car!!!! I really am not a fan of cutting up my car...I definitely understand that its a necessary evil...but I wish there was another option!!!
Re: csr trans sheild [Re: joshking440] #227337
02/26/09 12:49 AM
02/26/09 12:49 AM
I
I
Hi guys I got the dam thing in. I cut out the top of my tunnel, took the pan off and ground off the lip on the trans pan where the shifter linkage used the spacers to line up, so I wouldn,t have to use them , 2 guys putting it together, one guy on the bolt and the other guy pushiong and pulling as hard as he can to line it up. Tim
Re: csr trans sheild [Re: joshking440] #227338
02/26/09 09:36 AM
02/26/09 09:36 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
There is another option. An ultra bell and a blanket will pass tech for 9.99 and quicker.
